Excessive coolant consumption?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NM Lance, Jan 4, 2016.
  1. Jan 4, 2016 at 1:37 PM
    NM Lance
    NM Lance [OP] Well-Known Member
    2003 3.4 V6. Over 200,000 miles.
    I have had to add coolant twice in the last 6 months, roughly about a quart each time. I do live in a warm part of the country (100 degrees in the summer), but I am curious if this is normal. I cannot find any leaks, so I am a little concerned, especially since I have heard of multiple head gasket issues with the 3.4. I realize some of it will boil off. I have not pressure tested my cooling system, but I wonder if I need to.
    This is one of the "newer" vehicles I have owned. I have had to add to all my previous vehicles because they all leaked, whether it be from radiators or loose hose clamps. I am just not sure if this is normal for a newer engine.
  2. Jan 4, 2016 at 1:57 PM
    oldschoolbmx
    oldschoolbmx Well-Known Member
    Harry
    02' Tacoma TRD, 14' T4R SR5, 17' Tundra CM Ltd
    Magnaflow cat-back, K&N, B&M short shifter
    Could be the water pump seeping a bit. It would be hard to see without removing the timing cover. (That's what I call it).
    NM Lance[OP] likes this.
  3. Jan 4, 2016 at 2:39 PM
    NM Lance
    I checked my timing belt cover. No leaks there. I replaced my water pump with my timing belt about 20,000 miles ago, so that should not be an issue, at least for a while.
  4. Jan 4, 2016 at 3:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Assuming you have a non-leaking fluid overflow at the radiator cap, I would say any loss of coolant is a sign of trouble. It is definitely not normal for the 3.4L to use up coolant.
    FWIW, my water pump/timing combo belt is coming up on 80,000 miles with the same coolant. I have never had to add any.
    Based on the info you have given, I would say you have a small leak between one cylinder and a coolant port in the block. Most likely at the head gasket. The coolant is going into the combustion chamber and out the exhaust in gaseous form. Eventually you will be able to smell it in the exhaust as the rate of leak increases. Kind of a sweet smell.
  5. Jan 4, 2016 at 3:39 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    You may need a new radiator cap. I had a 98 Corolla that had mysterious coolant loss and it turned out to be evaporating through the radiator cap.
    NM Lance[OP] and ThorInc like this.
  6. Jan 4, 2016 at 3:42 PM
    NM Lance
    Certainly not what I wanted to hear, but I suspect you may be right. My overflow reservoir has never gained level, so my radiator cap is not relieving pressure. I guess I will pull my plugs and see if any of them are steam cleaned.
  7. Jan 4, 2016 at 3:44 PM
    NM Lance
    What is really a b1tch about this is my 2014 Tacoma has more issues than my 2003... My '03 has been my ace-in-the-hole.
  8. Jan 4, 2016 at 4:08 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Check your hoses for pin holes. They can leak a small amount that evaporates on something hot without dripping on the ground.
  9. Jan 4, 2016 at 6:31 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Another thing to check, is around your tranny. And back of motor. I have an internal leak under the manifold. Think it's the bypass tube. If there's a leak in there (could also be a freeze plug) it will pool up and seep out the back plate in back of engine. You will see signs of it leaking down the side and dripping off the tranny. that's what mine is doing anyways. To check even further, use an inspection mirror and go in from the passenger side of truck from the top or bottom and you should be able to find that plate. It's a hexagonal shape type plate that the heater bypass tube goes into. I go through coolant at about the same rate. Still trying to figure out what is entailed to fix it. And plan on tearing it down and doing a while top end rebuild anyways while I'm at it. But yeah, something to check into. I have some links bookmarked of a writeup regarding the process with pics if you do in fact discover you have this leak like mine. Take a look and let us know.
  10. Jan 5, 2016 at 8:00 PM
    jamco20
    jamco20 Well-Known Member
    James
    Socal
    Bilstein 5100's up front
    Is the Radiator original? Mine started leaking at about 185,000 and I couldn't tell because it was so small. the leak was on the drivers side lower corner of the radiator. It was like a hairline crack.
  11. Jan 5, 2016 at 10:03 PM
    NM Lance
    That is the next thing I will check. It has been muddy and wet in my area, so I am struggling to identify leaks at the moment. My radiator is original, and I have not really been diligent about changing out my coolant throughout the truck's life.
    toendanger mentioned a bypass tube. I checked around my transmission where he thought it may leak, but did not really see any leakage there.
    This is really bothering me because the last thing I want to do is start tearing into the top end to replace a gasket... So I hope it is just a leak that I am not seeing.
    I appreciate everyone's input!
  12. Jan 6, 2016 at 10:21 AM
    jamco20
    James
    Socal
    I've never heard of a head gasket blowing or even leaking on a 3.4l. I'd check the bottom of the radiator really good. Have you checked the oil for coolant?
