Excessive Driveline Vibration When Accelerating (Help!)
Discussion in '1st Gen. Tacomas (1995-2004)' started by SteelHippo, Nov 27, 2024.
  1. Nov 27, 2024 at 5:55 PM
    SteelHippo
    SteelHippo [OP] Member
    Hunter
    1999 Tacoma SR5 2.7 5 speed 4x4
    3" lift, 33" tires
    So my Tacoma developed a driveline vibration a number of weeks ago... and I'm completely stumped. It started out as a very noticeable, but not that awful vibration when accelerating in 3rd gear, and then drove fine at highway speeds. Then it became worse and started happening on 2nd AND 3rd gear acceleration a few days later, and one night it all of a sudden got so bad that it was shaking so violently on my way home at pretty much any speed that I decided to park it once I (felt like barely) made it home. I got underneath it the next day and determined my carrier bearing was shot (lots of play in all directions, I should add that I also checked the U-joints for play and they felt rather tight with minimal play) and the symptoms made sense, so I decided I needed to replace the carrier bearing. I have lots of projects atm so it ended up sitting for about a month and I just drove a different vehicle, until I finally ordered a bearing and put it in today. I bought the Spicer carrier bearing that I've heard lots of good things about on this forum, and I don't particularly believe it to be the culprit... but the vibrations on acceleration still persist with the new bearing installed.
    One very interesting thing to note is that it did actually fix the problem to a small extent. The best way I can describe it, is that it's now the same way it was roughly a week before it started to go seriously bad and shaking at all speeds (so slight shaking in 2nd on accel, more prominent shaking in 3rd on accel, will go down the road at 45-55 alright). Another thing to add is that I'm sure its in the driveline because it won't do it if I'm coasting or shifting from 2nd to 3rd, but it doesn't really matter what gear I'm in that much either; if I try skipping 3rd (since it seems to be the worst at 3rd gear speeds) it still does it in 4th gear, just at lower RPMs.
    Any help and input is much appreciated, I'm kinda at the end of the road with what I can think to try. I don't want to just throw parts at it as my bank account has taken some serious blows lately not to mention the waste of time... but I'm wondering if I should just try a new driveshaft or U-joints, even though mine appears to have very minimal play (feels like less play than my 03 Sequoia which drives great)? This has been very frustrating and I really don't want to take it in somewhere as I like doing my own repairs.
  2. Nov 27, 2024 at 5:58 PM
    Bishop84
    Bishop84 Well-Known Member
    U joints as a next step. They can look good, feel free, but cause wild vibrations under load.
    If you want to make sure putting the rear axle on jack stands and running it up to speed while watching the shaft will help visualize it.
    SecureIT2021 and Black97v6MT like this.
  3. Nov 28, 2024 at 9:17 AM
    Glamisman
    Glamisman Well-Known Member
    Check to see if the driveshaft has thrown a weight.
    SecureIT2021 likes this.
  4. Nov 28, 2024 at 8:46 PM
    dustytaco89
    dustytaco89 Active Member
    2004 Tacoma Prerunner
    I had this same problem with my ‘04 automatic. I was also sure it was the driveline bc I put it into neutral while driving and all the vibration and noise went away. It ended up being the Ujoints although the carrier bearing was replaced as well (305k on it). Are you hearing any noise when you reverse?
  5. Nov 28, 2024 at 8:50 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    U Joints can be tight feeling but totally trashed internally. If they feel stiff, they are bad. They should rotate easily and smoothly in all directions when tested by hand.
  6. Nov 28, 2024 at 8:55 PM
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    U joints can develop play which is easy to check. U joints can freeze which is hard to check. since you have another vehicle to drive, I'd pull the shaft and send it out to a driveline shop. They'll replace all of the u joints and spin balance the shaft. You'll essentially have a new rebuilt driveline and if there's a vibe after that, you know it's not the drive line.
  7. Dec 7, 2024 at 12:53 PM
    SteelHippo
    Hunter
    3" lift, 33" tires
    Thanks for all the replies, I'll have to see what driveline shops are around me that I could take the shaft to. Definitely makes sense for u-joints to be bad at 266k miles even though they felt fine by hand with shaft installed
  8. Dec 7, 2024 at 1:14 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    A few of us have had our rear drums cause vibrations unrelated to braking. Swapping in a new set of drums might fix your issue if the driveshaft shows no issues after inspection.
  9. Dec 9, 2024 at 2:59 PM
    SteelHippo
    Hunter
    3" lift, 33" tires
    I replaced my rear drums about 4 years ago with new ones, and the vibration also stops if I let off the gas pedal regardless of speed, so probably unlikely. Although that's definitely good to know, I've known about warped rotors causing wobbles/vibrations but never thought about the possibility of warped drums too.
  10. Dec 30, 2024 at 7:28 PM
    SteelHippo
    Hunter
    3" lift, 33" tires
    Just wanted to write an update for anyone who was curious; I went to pull my driveshaft and noticed as I was removing it from the rear diff that the rear most u joint was absolutely shot. When I was loosening the bolts, the input on the diff rotated about a 1/2" and the drive shaft remained still. Not sure how I didn't notice that earlier when I checked... but anyway, I got a new u joint and just replaced the one that was shot, as the others were very tight still and moved smoothly. Put fresh grease in all of them and reassembled, drives smoother than it has in quite some time now.
    SecureIT2021, ztwatson and Bishop84 like this.
  11. Dec 30, 2024 at 10:52 PM
    coylifut
    tk
    portland or
    Thats a great share. Thanks for the update.
  12. Dec 30, 2024 at 11:41 PM
    SecureIT2021
    SecureIT2021 Well-Known Member
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    Your post caught my eye. We have similar models. I was talking with my mechanic not too long ago about the exact same issue, only the vibrations I felt weren't excessive, but noticeable. Glad you got it resolved.
  13. Dec 31, 2024 at 8:19 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    This was the smoking gun. You gotta disconnect the shaft to check the u joints unless they are totally shot.
