Excessive engine vibration.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, May 11, 2024.
  1. May 11, 2024 at 10:30 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Hey guys I have posted numerous times about my 2023 tacoma v6 having an abnormally strong vibrations coming from the engine while driving and idling. After many trips to the dealer and inspections myself I was gonna give up. Truck has 5k miles on it and today I decided to look at the crank pulley/harmonic balancer as it was the last possible thing I could think of and using a mirror and flashlight I can see the whole rubber ring on the pulley is cracked all over the place. I’m thinking I finally found the problem but then again not sure. Hard to believe the amount of cracking could be normal for a truck with 5k miles. Any thoughts?
  2. May 11, 2024 at 10:33 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Definitely not normal. Take it to a dealership and have them look at it, pointing out what you see. Could be defective compound in the material of the pully ring.
    Don’t panic though. If it is that causing the vibration the fix should be as easy as replacing it.
    Gfenza89[OP] likes this.
  3. May 11, 2024 at 10:36 AM
    Gfenza89
    Thank you I deff will!
  4. May 11, 2024 at 10:57 AM
    Gfenza89
    I’m thinking you are right. This has been an issue since driving the truck off the lot back in september. No way should it be cracked like that with 5k miles
    t0p_d0g likes this.
  5. May 11, 2024 at 11:19 AM
    eurowner
    eurowner Duke Sky
    Scoty
    :worthless:
    Canadian Caber likes this.
  6. May 11, 2024 at 11:20 AM
    Gfenza89
    I can’t get pictures very well. Pulley is down to far
  7. May 11, 2024 at 1:41 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If your engine has a vibration at any rpm idling etc. you may have found the issue. Either way it’s not normal and Toyota needs to make it right.
    It could be a number of things even something internal.
    Gfenza89[QUOTED][OP] likes this.
  8. May 11, 2024 at 1:58 PM
    Gfenza89
    I’m pretty sure I found the culprit. It’s most of the time rough
  9. May 11, 2024 at 1:58 PM
    Gfenza89
    Check your
