Excessive loss of oil ...shooting it out the tailpipe
Discussion in '4 Cylinder' started by slm1nslm2, Feb 16, 2015.
  1. Jul 25, 2016 at 8:30 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Okay what color is the crap shooting out the tail pipe. Black is too rich, blue is oil and white is typically coolant.
  2. Mar 23, 2021 at 10:05 AM
    slm1nslm2
    slm1nslm2 [OP] Member
    Sacramento California USA
    05 Base level Tacoma
    Feeling guilty I never concluded this issue and I hate that. Sorry it took so long. This is how the truck turned out. Didn't solve the burning of oil although it lessened to about a quart between changes after changing ignition paks and basic tuning. That pretty much solved all issues with soot(oil I thought) shooting out the tail pipe. I kept this truck on planned non op and used it sparingly. The goal then became to smog in California. Wasn't going to be easy with all that unburned fuel, soot, oil or whatever that had been coating the substrate on the CATS over at least 25k. . I ended up with the dreaded Catalyst code, I can't remember the #. I tried everything under the sun to get my CAT to work....Everything! air/fuel sensors lacquer thinner I think it was. Acetone. Oven cleaner, Pressure washer. Soaking, Hot, Different soapy, degreaser, commercial products, and nothing worked. Over $1500 for a new one. Had to be Calif. or New York specific and it's illegal for a dismantler to sell a CAT in Calif. I was not deterred. Long story of several failed attempts, eventually leading to me to ask for an exhaust pipe etc etc..... never mentioning Catalytic Converter rather describing the "pipe" downstream of the manifold. I was able to get a used one from a dismantler $600. Tricky too because if it didn't work sure I could return it but I had to give up my original as a $200 core that they would not hold onto. It was a struggle, fortunately it worked and passed smog. I sold the 2005 2.7 base access cab about a year ago running good for $3200. 278k and all is well. Sporting a 1st Gen Tundra now. Which is very near the size of a Newer Tacoma BTW so There you go. IGNITION PACKS
    SR-71A and 0xDEADBEEF like this.
  3. Mar 27, 2021 at 11:14 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Piston rings are shot. My truck did the exact same thing. Full rebuild or LS swap is your future my friend
  4. Mar 27, 2021 at 11:25 AM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    its oil for the muffler bearings :thumbsup:
    im thinking valve seals are bad
  5. Apr 2, 2021 at 5:03 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    U mentioned that U had taco 6 days = bought used ?????
    what do the plugs look like ???
    160 psi compression stone cold or warm motor ????
    1/2 quart is excessive ..........stop driving hard /redlining engine until U can find out whats wrong
  6. Apr 2, 2021 at 5:06 AM
    ROAD DOG
    FEW
    so is it oil or soot
    soot could be a direct product of ‘ blow by ‘ + engine running very rich
  7. Apr 2, 2021 at 5:15 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Almost 6 years later the story concludes :D
