excessive Oil Consumption
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Holeshot, Jul 17, 2015.
  1. Jul 17, 2015 at 6:34 AM
    Holeshot
    Holeshot [OP] Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Toyota salesman told me to watch for news about a class action lawsuit concerning excessive oil consumption in late model Toyotas including Tacomas.
    Anyone else have information to support this or a Toyota contact who can confirm or deny this?
    Thought I was through with this issue when I went from '08 Sierra with 5.3L AFM engine to 2015 Tacoma 4.0.
  2. Jul 17, 2015 at 6:44 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Ding
  3. Jul 17, 2015 at 7:01 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I never check my 08 and never checked my 2000. I don't think there is a problem with Tacoma's. I've head some Honda's and some German cars have bad problems. I haven't bothered to get details since I don't own them but Honda is rebuilding some engines because of rings and the German company says it's normal to use a quart every 500 miles.
  4. Jul 17, 2015 at 7:09 AM
    chunt5
    chunt5 Senior Citizen Member
    chuck
    Cumming, Georgia
    2015 DCSB, Prerunner, SR5, 4.0
    Excessive oil consumption is a "major' issue for 2007 - 2009 I4 Camry's and other Toyota's that use the same 2.4L engine. It is not a Tacoma problem. Toyota is currently rebuilding high mileage 2.4 engines from these years under warranty.
    dakotasyota likes this.
  5. Jul 17, 2015 at 7:26 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    There is something on this for Scions. A guy I work with just had his XB tested and is waiting for the parts to come in. They are putting all new rings in his motor. The test consists of the dealer filling the oil and sealing it then the customer driving it for a week. Customer returns and the dealer checks the level, if it's more than 1 quart low it fails. The guy at my work was over 2 quarts low.
    I've never heard of this on a Tacoma though and whenever I check mine it's always been good. I never lose any oil.
  6. Jul 17, 2015 at 7:46 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    Mine after 5k miles is right at or darn close to where I fill up to. I am at 75k miles now. Racking em up quick. One change I missed it till 7500 because I was busy, and it was fine. Oil was still nice looking(even though that doesn't mean a lot)
    gnorv likes this.
  7. Jul 17, 2015 at 7:51 AM
    chunt5
    chuck
    Cumming, Georgia
    Actually the test is they seal everything up and you drive it for a 1,000 miles and then recheck the oil.
  8. Jul 17, 2015 at 8:13 AM
    Holeshot
    Gary
    Alabama
    This is the test the Salesman described. He said Toyota's position that using 1 quart in 1200 miles was reasonable. He disagreed and said no oil should be needed between 5000 mile oil changes.
    I would be freaking livid if my 2015 started doing this. Just had my first 5000 mile service done and will watch my oil level.
    Did review paperwork after leaving dealership and noticed the tech used 5w/20 instead of the specified 5W/30 on my oil change came back next day and 50 miles later and they replaced with correct oil. Glad I had read owners manual and recognized that they used oil specified for 4 cyl. Instead of V6.
  9. Jul 17, 2015 at 10:59 AM
    Holeshot
    Gary
    Alabama
    I think you are likely correct but why would Toyota specify different viscosity for the four cyl. Than the V6 if it does not matter?
  10. Jul 17, 2015 at 11:05 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    My 13 doesn't burn any oil and I check it once a week. It always checks out to be good.
    Rambo54 likes this.
  11. Jul 17, 2015 at 1:14 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I use zero oil in between 5K oil changes in all of my Toyota's. According to Toyota math, it would be reasonable to use 4 qts. or a gallon of oil in between a 5K oil change. I do believe Toyota's position is ridiculous. That's a lot of oil getting past something.
  12. Jul 17, 2015 at 1:17 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  13. Jul 17, 2015 at 1:30 PM
    MGMTacolover55
    Orygun
    floor Mats
    Toyota uses the 1GRFE engine so this lawsuit doesn't affect us.
    Rambo54 likes this.
  14. Jul 17, 2015 at 2:07 PM
    Lester Lugnut
    One of my in-laws owns one of these - 2007 Camry 4 cyl. I maintain it. 47K and no oil usage. Fingers crossed.
  15. Jul 17, 2015 at 2:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well, You really don't keep them long enough to check the oil. :)
  16. Jul 17, 2015 at 2:45 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    This isn't just toyota, Subaru has had the same issue. My wife's 13 forester just had the lower block replaced under warranty because of oil consumption. Subaru must trust its customers more because they don't seal anything up, just ask you to come back in 1200 miles for the test.
  17. Jul 17, 2015 at 3:28 PM
    Holeshot
    Gary
    Alabama
    Happy to learn our 1GR v6 engines are not affected.
    Rambo54 likes this.
  18. Jul 17, 2015 at 4:13 PM
    george3
    New Jersey
    So I guess BMW is the German company. It doesn't affect my Taco or my wife's Honda either.
    scottalot[QUOTED] likes this.
  19. Jul 17, 2015 at 11:04 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    A few visits back, I asked the Service Advisor if there were any issues with the new corollas(my wife has one) and he said there wasn't. But he did mention something about older toyota vehicles with high oil consumption that Toyota Corp will be eating the cost on replacing their engines. From what I remember he mentioned corolla, scion tc/xb, camry and rav4's. Which ever engine covers most/all of those vehicles is the issue. And if you paid out of pocket for your engine to be replaced on the affected vehicles, Toyota Corp. would reimburse you.
    We all know how Warranty/TSB issues work... You have to work for the issue/s to get resolved, they usually don't just give the no cost to you fix off the bat.
    If I came across one of the affected vehicles, I would buy it to get the new warrantied engine from Toyota at no cost!
  20. Jul 18, 2015 at 4:35 AM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    You made a good choice on the Tacoma. I came from an 08 Chevy with the AFM 6.0(Vortec Max), it not only consumed oil and ticked(which the dealer told me was normal while under warranty) but a month out of warranty one of the AFM lifters shit the bed and took the lobe on the cam out with it. The dealer wouldn't do anything. GM Corporate told me tough luck since I wasn't the original owner. A $3000 screw you from GM. Never again will I own a GM vehicle.
