Excessive play in the carrier bearing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by d33pt, Nov 26, 2022.
  1. Nov 26, 2022 at 2:49 PM
    d33pt
    d33pt [OP] Well-Known Member
    Seems pretty excessive to me, but I've never checked it before. Angle doesn't seem too bad. Do I need a spacer? Have about a 3" lift in the rear. Surprisingly, I'm not getting any crazy vibrations.
    Also for a replacement, which Spicer part is better? Both are about the same price. Or should I go OEM? About 3x the price for OEM, which I hear is Spicer anyway. There is also Timkin, which is a little more than the Spicer.
    DANA 252117501X Spicer Select
    DANA 2117501X Spicer
  2. Nov 26, 2022 at 6:07 PM
    okie18
    okie18 Member
    Jace
    95 tacoma
    That's not too bad. It's a hollow rubber donut so it's gonna have some give, that's it's job. A spacer wouldn't hurt.
    I'm pretty sure spicer is oem, it has the Toyota symbol stamped in the donut. I used the non select part number. The select is probably the same thing with a upcharge.
  3. Nov 26, 2022 at 6:38 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  4. Nov 26, 2022 at 6:40 PM
    O'Silver_Taco
    MD
    I would be leary of knockoffs.....even spicers.....
    might want to bite the bullet and find a real toyota dealer for this item....
    MaxTorque likes this.
  5. Nov 26, 2022 at 10:28 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  6. Nov 28, 2022 at 11:53 AM
    MaxTorque
    MaxTorque Hope is not a strategy...
    Maryland
    cup holders
    Yours isn't bad enough to warrant replacement. I've seen them a lot worse and the customer didn't know it until I showed them while doing other work. Keep an eye on it, and if you notice a driveline vibration when driving then it may be time. It's the rubber that generally wears out before the bearing goes bad. Buy OEM. I don't say that on many parts but for whatever reason the aftermarket ones have issues. Some say Spicer makes the OEM part for Toyota but when I ask where they got that info they said "they heard...". There is a top and bottom, front and back orientation, so observe that when the time comes. OEM comes pre-packed with grease. And as another posted, replace the locking nut also. And last, there may be thin washers/shims stuck to the inner race on the old bearing, so be sure to transfer.
