Excessive Power Steering Noise
Discussion in 'Technical Chat' started by PcBuilder14, Feb 1, 2013.
  1. Feb 10, 2013 at 3:28 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Empty it via that little curved down spout on the side of the reservoir.
    It has a hose on it.
  2. Feb 10, 2013 at 3:41 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    IMO if it's not broken, don't fix it. Toyota has a great way of fixing its problems by putting more miles on it lol.
  3. Feb 10, 2013 at 4:23 PM
    goomba
    Josh
    San Antonio Fl
    If he does not do anything it will burn up the pump.
  4. Feb 10, 2013 at 4:28 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    A lot of the time when it's cold the power steering pump will give you a whine, sometimes a gurgling and sucking sound. It gets better as it warms up. My boss's '98 Dodge 2500 does this all the time when the temperature is below 40-45.
  5. Feb 10, 2013 at 5:03 PM
    goomba
    Josh
    San Antonio Fl
    Ya. Cold oil is thick oil. Does not pass through the screen as easily.
  6. Feb 10, 2013 at 5:07 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    have you ever topped it up with fluid? if so, did you use power steering fluid or automatic transmission fluid?
  7. Feb 10, 2013 at 5:13 PM
    goomba
    Josh
    San Antonio Fl
    O snap. Good question. Only ATF fluid.
  8. Feb 10, 2013 at 6:14 PM
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Fluid is at good level.
  9. Feb 13, 2013 at 7:21 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    but what kind of fluid, if you have ever put in power steerig fluid, you wrecked your pump, sounds weird but it happened to my 01. it calls for ATF (automatic transmission fluid)
  10. Feb 13, 2013 at 7:24 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I know 1st gen tacomas are weird about the fluid for the power steering pump. I haven't added anything to it since I bought it. The noise is almost gone now that there's been a few warmer days here. I honestly think I just need to clean the filter out and all will be good.
  11. Feb 18, 2013 at 10:28 AM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Any update on this. I have the exact same noise. Not all the time, but does it frequently. Has that weird hum when turning at lower speeds too.
    When I disconnect the hose, do I need to worry about air getting in the system? Or do I just disconnect, drain the reservoir, clean filter with brake cleaner, reinstall, then fill with ATF?
  12. Feb 18, 2013 at 11:11 AM
    SpeedoJosh
    Florida
    Just went and looked in truck. Appears you have to disconnect the belt from pulley, and remove the whole assembly. Can I just remove the reservoir without taking off the pump?
    EDIT**
    Nevermind. Was able to get the reservoir off without taking off the pump. Letting it soak now. Screen was completely clogged. Going to flush the system tomorrow, but wanted to clean the screen first. Might do the mod where you drill out a section of the screen, then place an in-line filter on the return hose. Don't want to do it until I get clean fluid in there though since I feel the screen will catch more crud then the in-line filter.
  13. Feb 18, 2013 at 4:01 PM
    goomba
    Josh
    San Antonio Fl
    To get the air out you just turn your wheels back and forth slowly and hold at the bump for a few seconds. Gets the air right out.
