Excessive Tire Wear
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyasu45, May 27, 2009.
  1. May 27, 2009 at 3:31 PM
    crazyasu45
    crazyasu45 [OP] Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I have a set of new tires on which only have a couple months of wear. my problem is, on the front tires I've noticed there is excessive wear on the outer edges. Any thoughts?
    Thanks,
  2. May 27, 2009 at 3:33 PM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    under inflation.... start with that.
  3. May 27, 2009 at 3:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ^^^^^^yep...start with air pressure, then check your shocks/suspension.
  4. May 27, 2009 at 3:34 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    to the chalk test to find the best tire pressure
  5. May 27, 2009 at 3:35 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    sounds more like improper alignment to me.
  6. May 27, 2009 at 4:02 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    That's what I'm thinking...The tires are inflated to 35psi...or incorrect Toe or extreme camber...I'll have to get it checked out
    Thanks for the input
  7. May 27, 2009 at 4:34 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    It's probably the alignment if you're running 35 psi. Do you have curvy roads and drive around corners fast? That will wear the outer edge a lot faster as well(personal experience :D).
  8. May 27, 2009 at 4:51 PM
    RelentlessFab
    Eric
    Sparks, NV
    Actually, if there were too little air pressure, then the center of the tire doesn't give enough support and the majority of the weight is transferred to the edges of the tread thus leading that part to wear quicker.
  9. May 27, 2009 at 5:04 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    will wear tires everytime. just get the camber close as possible to factory settings. and make sure the toe is dead on or extremely close. Toe is what wears the tires out faster. Here is a little bit of information to those who dont know, or are curious.
  10. May 27, 2009 at 8:49 PM
    RelentlessFab
    Eric
    Sparks, NV
    Yeah, a little. Pics would help, but it just sounds like the outward facing edge of the tread. That would attributed be alignment issues and 'spirited' driving most likely.:cool:
  11. May 28, 2009 at 3:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How old are the tires and what kind are they?
    If they are older and getting close to the end of their life span, they could just be wearing funny because they are old.
    But if they're fairly new and good - most likely an allignment issue.
    How often do you rotate your tires?
  12. May 28, 2009 at 3:57 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Go with the toe doncha know. Just get an alignment. If one hasn't been done in a great while then it's always worth the damn 50-70 bucks for an alignment when getting new tires, especially when they generally cost the better part of 1000.00 bucks for a new set of anything decent. Hell, pay 100.00 for the 1 yr alignment from NTB & get free checkups every 5000k if needed.
