Excessively High Idle When Warm
Discussion in '1st Gen. Tacomas (1995-2004)' started by silverbullet02, Nov 13, 2018.
  1. Nov 13, 2018 at 10:31 AM
    silverbullet02
    silverbullet02 [OP] Well-Known Member
    Cole
    Minnesota
    2002 Reg Cab 2.7 5MT 2013 Access Cab Baja 6MT
    Check out my builds! ----->
    2002 Tacoma, 2.7L Manual Transmission
    I have been noticing that as the days get colder, my truck's cold start seems abnormally low at around 600-1100 rpm's. As it gets up to operating temperature, the idle speed steadily increases up to around 1800-2000 rpm's. If I rev the engine a little, the rpm's drop down before climbing back up to 1800-2000.
    In addition, my UltraGuage indicates the truck is permanently stuck in a open loop. I have one check engine light code, P1135. From what I have read this is for the upstream O2 sensor, which I just ordered yesterday. Would a bad O2 sensor be a realistic cause of the high idle? I also plan to clean out the throttle body and replace spark plugs this weekend. Would cleaning the MAF be beneficial as well?
    I've done a fair bit of searching online, but I have not been able to find similar issues to mine, only the opposite (low idle when warmed up).
  2. Nov 13, 2018 at 10:54 AM
    02hilux
    Planet: EARTH
    Personal opinion, a defective o2 shouldn't cause high idle. Check and clean your idle air control valve on your throttle body if you got one.
    Boatbldr likes this.
  3. Nov 13, 2018 at 11:12 AM
    silverbullet02
    Cole
    Minnesota
    Good idea, I will clean that as well.
    The odd thing is that I never noticed a high idle like this in the summer, which leads me to believe that it has something to do with air, since colder air is denser and whatnot.
  4. Nov 14, 2018 at 8:11 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Pretty textbook symptoms of a vacuum leak.
    J.A.92 likes this.
  5. Nov 15, 2018 at 5:56 AM
    silverbullet02
    Cole
    Minnesota
    That's what I was worried about, I will have to check the lines after cleaning the TB and IAC
  6. Nov 15, 2018 at 11:41 AM
    Geck74
    Geck74 Member
    Allen
    Topeka, KS
    96 Tacoma Reg. Cab 4x2
    If you have an OBD scanner, you can verify the accuracy of sensors that directly affect fuel trim. I had a high idle on my truck last winter when it was warmed up. Found out that I had a bad coolant temp sensor telling the ECM that my engine was at 90 degrees F when it was more like 180 degrees F. Swapping that sensor out fixed it.
  7. Nov 15, 2018 at 8:08 PM
    silverbullet02
    Cole
    Minnesota
    This afternoon I cleaned the throttle body and IAC. It was fairly dirty, and the IAC valve seemed to be stuck open a little bit. I gave both a thourough cleaning but didn't have the right screwdriver to get the IAC solenoid/motor off, so if the issue persists I may take everything apart and try again when I do spark plugs.
    I did go for a little drive afterwards and I think the issue may have been solved! I will know for sure after my drive to and from school tomorrow.
    cruiserguy likes this.
  8. Nov 25, 2018 at 9:03 AM
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    What did u use to clean sensers with ?
  9. Nov 25, 2018 at 11:14 AM
    silverbullet02
    Cole
    Minnesota
    I used NAPA CRC brand throttle body cleaner. I wanted something specific to for throttle bodies as I read that carb cleaner can take the protective coating off of the IAC and butterfly valve.
    https://www.napaonline.com/en/p/CRC092400
    In other news, the issue seems to have completely gone away! I'm hoping to see some better fuel mileage, but regardless I'm glad to see a normal idle and warmup cycle.
    cruiserguy and Boatbldr[QUOTED] like this.
  10. Nov 25, 2018 at 11:27 AM
    Boatbldr
    Florida
    2002 prerunner
    None
    Thanks I'm having similar issues. I shimmed out advanced whatever that's under throttle to get truck home to garage. Runs fine this way for now. Truck was dropping under 500rpm and stalling. First time I have this problem. I have had high idle issues in past briefly
  11. Nov 26, 2018 at 2:01 PM
    silverbullet02
    Cole
    Minnesota
    I wasn't having any issues until the weather turned colder. If that's the case with you then maybe it's the same issue!
    Boatbldr[QUOTED] likes this.
  12. Nov 26, 2018 at 2:18 PM
    Boatbldr
    Florida
    2002 prerunner
    None
    Its my dashpot. It was stuck back. Cleaned my EGR filter blew some sensor cleaner into dashpot freed it up. Vacuum systems I find are most over looked area. I'm going to continue to clean and research vacuum system in truck. And yes we finally got some cool air but Its still hot during day and high humidity and night dew point temps here, I got my AC back on now. Couple of days without it and windows open.
  13. Nov 26, 2018 at 2:44 PM
    silverbullet02
    Cole
    Minnesota
    Good to hear! Glad you figured it out
  14. Nov 26, 2018 at 2:49 PM
    Boatbldr
    Florida
    2002 prerunner
    None
    I still have work to do I'm looking at cable springs and all. Truck has 340000 on it runs great. I would would like to get to half million mile on it like I did my 79' Bronco. Little old lady totalled it for me.
