Exchanged 3" Spacer lift for 5100's/Eibachs
Discussion in 'Suspension' started by KirbSide827, Mar 9, 2012.
  1. Mar 9, 2012 at 6:35 PM
    KirbSide827
    KirbSide827 [OP] Active Member
    North Alabama
    TRD Off Road 4x4
    5100's @ .85, Eibach Springs w/ top spacer, 1.5'' block in rear, 275x18 Nitto's
    I bought my 08 DC TRD OR a little over a year ago. It was my first actual truck and though I've driven 4x4 suv's in the past, I didn't know much about lifts. I just knew it had a 3" lift on it. I drive 60+ miles a day and the vibrations and overall rough ride left something to be desired. After discovering TW and researching lifts, I decide to go with the 5100s @ .85 & Eibachs with top spacer (1/2" DS, 1/4" PS). I also added a carrier bearing drop. I also changed out my bald Mickey Thompsons for Nitto Terra Grapplers (still a fan of "Letters Out").
    Before:
    After:
    Measurements
    Before
    Front - 22 3/4" DS, 23" PS
    Rear - 23" both sides (1/2" block)
    After
    Front - 22 3/4" both sides
    Rear - same
    For anyone considering a spacer lift, I would tell you not to do it. My truck rides like a new truck and I couldn't be happier. The vibrations are totally gone. Some of it was the fact that I probably needed an alignment and my tires needed to be rotated, but not all of it. My truck handles the road so much better and small bumps no longer shake me all over the road.
  2. Mar 9, 2012 at 6:38 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Glad you left the dark side. Spacers are always a no go.
    Your truck looks great :thumbsup:
  3. Mar 9, 2012 at 6:43 PM
    KirbSide827
    North Alabama
    TRD Off Road 4x4
    Thanks. I was hoping it would be a drastic change...which it has been. I feel like this is what it would have driven like stock.
  4. Mar 9, 2012 at 7:14 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Hopefully this Sunday ill get to install my billys. I'm sitting stock right now
  5. Mar 9, 2012 at 7:46 PM
    txduckhunter
    txduckhunter Well-Known Member
    centex
    08 Tacoma DC LB SR5 4x4
    2.5" lift, ARE Shell, Ducks Unlimited Rubber Floor Mats. ROGUE badges,
    What size rims and tires are you running? They look super beefy bro!
  6. Mar 9, 2012 at 7:54 PM
    RedDragonTaco
    RedDragonTaco Knight Industies Toyota Tacoma
    Slc, UT
    2007 Double Cab TRD Sport
    Toytec 3" Ultimate w/ LR UCA's, 18" Rockstar rims, Nitto Grappler 285/65/18, OEM roof rack, foglight anytime mod, front bull bar and Smitty side steps, tonneau cover, debadged, BHLM, blacked out tail lights, stubby antenna, flowmaster
    Nice work, I think its an improvement all around
  7. Mar 9, 2012 at 7:58 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    when you say you were having vibrations what sort of vibrations? i ask because i have a spacer as well and considering getting rid of it too.
  8. Mar 10, 2012 at 8:53 AM
    KirbSide827
    North Alabama
    TRD Off Road 4x4
    Sorry guys I had to get off the site a little early last night. My wife and I have a 2 week old little boy, so I don't get to stay on TW as much as I usually like to.
    I'm running 275x70x18's. A little trimming was done before I bought it and I've had to do a little more since exchanging the lift and tires.
    I was having real bad wheel shake at 45-55 mph and some up to 70 mph. It was bad enough that I felt like my brain was being shoke out of my head if I laid my head against the headrest. I had an alignment and of course my new tires were balanced, but I think the carrier bearing drop has made the most difference. I've had the tires balanced before and it helped some, but not much and not for long.
  9. Mar 10, 2012 at 3:45 PM
    2000GTacoma
    Snow Hill NC
    im having some issues as well planning on replacing the tires as soon as funds permit with a set of michelins ms 2.
  10. Mar 10, 2012 at 3:48 PM
    KirbSide827
    North Alabama
    TRD Off Road 4x4
    what kind of issues?
  11. Mar 10, 2012 at 4:36 PM
    2000GTacoma
    Snow Hill NC
    vibrations around 45 mph i currently have firestone destination mts and they have worn very uneven even with rotation every 3000 and having my alignment done alone with new lower control arm bushings and inner and outter tie rod ends
  12. Mar 10, 2012 at 5:04 PM
    KirbSide827
    North Alabama
    TRD Off Road 4x4
    I'm really happy with the Nitto's so far. They are much quieter than the MT's. I think the carrier barrier drop really helped b/c I felt like the vibrations came from the center of the truck.
  13. Mar 10, 2012 at 5:07 PM
    slodc4
    slodc4 Conceal Carry
    Steven
    Pink Hill, NC
    07 TRD SR5 offroad
    LIFTED
    nice truck, whats the rear suspension setup?
  14. Mar 10, 2012 at 5:24 PM
    2000GTacoma
    Snow Hill NC
    i have taken the entire drive shaft out had it balanced and gone through by a driveline company and it made no difference. took the driveshaft out drove down the road with the front end pulling same thing. so i know its not the rear driveshaft.
  15. Mar 11, 2012 at 9:01 AM
    KirbSide827
    North Alabama
    TRD Off Road 4x4
    Thanks. I've got the 5100's in the rear with an 1 1/2'' block. I debated an AAL, but I liked the height I had in the rear already and wanted to leave it alone to start with. I'm still happy with it. All I ever pull is a 4 wheeler and I don't haul much, so sagging is not an issue.
  16. Mar 11, 2012 at 9:02 AM
    KirbSide827
    North Alabama
    TRD Off Road 4x4
    Sorry to hear that. Hopefully new tires will make a difference.
  17. Mar 11, 2012 at 11:00 AM
    09 Redneck
    09 Redneck Reaper
    Ga
    2018 SR DC 2.7L
    Does your truck have the rear TSB?
  18. Mar 11, 2012 at 12:48 PM
    KirbSide827
    North Alabama
    TRD Off Road 4x4
    No, just the 1 1/2'' block.
