EXCUSE THE TYPO TW. where to find EyeLIDS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YoungGunz23, Aug 31, 2011.
  1. Aug 31, 2011 at 2:25 PM
    YoungGunz23
    YoungGunz23 [OP] Well-Known Member
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    3" fabtech lift 33" federals
    sorry. try again on this thread
  2. Aug 31, 2011 at 2:27 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Ebay but you'll have to get them painted or do it yourself.
  3. Aug 31, 2011 at 2:27 PM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    ^ ebay, like Mike said.
  4. Aug 31, 2011 at 2:28 PM
    YoungGunz23
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    i have seen people with color matched ones? do they have to paint them
  5. Aug 31, 2011 at 2:30 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    why no stick with the eyelashes!? I thought it was a great idea:eek:
  6. Aug 31, 2011 at 2:30 PM
    Pugga
    Massachusetts
    Yes, unless they've found a place where they come pre-painted. A lot of people have connections to get them painted or do it themselves using color matched spray paint. For superwhite, it's tough, a lot of color matched paints have a little yellow tint to them. I had a set and gave up after trying 3 different places (not to discourage you from painting yourself, I'm just very picky). Try paintscratch.com, they make color match spray paint and are good to deal with. They were also the closest match I could come up with to the factory paint.
  7. Aug 31, 2011 at 2:32 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    ebay and see attachment :D
  8. Aug 31, 2011 at 2:36 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Both are hot
  9. Aug 31, 2011 at 2:41 PM
    rleeharris
    Bob
    San Antonio, Texas
    Buy them and paint yourself if this is the look you are going for.
    Duplicolor and ColorRite make rattle cans--use the paint code for your Taco. Just prepare the surface with a nice automotive primer and then spray on the first coat. Always sand between coats with 600+ grit sand paper and make sure to clean the surface before spraying the next coat. Once you are satisfied with the color depth and match to your vehicle, finish with an automotive quality clear coat. Sand again, if you desire, and then add a second coat of clear. When spraying and drying, make sure you are doing this in a location as free of contaminants and dust as possible. Also, if local weather indicates high humidity, wait until it's dryer. Nothing ruins a paint job more than high humidity.
    Not much to it. Been doing this in my garage for years to motorcycle farings, sliders, grille guards, and other small pieces for years. I never pay anyone and they all turn out well. Just take your time. These pieces are so small that even minor imperfections will hardly be noticeable. Otherwise, you can pay a shop to do it for you depending on how much cash you want to lay out on the project.
