Execution, Resurrection, Redemption...A Tacoma Story
Discussion in '1st Gen. Tacomas (1995-2004)' started by jberry813, Aug 11, 2011.
  1. Aug 11, 2011 at 11:07 AM
    jberry813
    jberry813 [OP] Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I have a lot of this information in my build, but there's a lot of BS in my build as well and I know most people don't wanna read that shit. There's a lot of good pictures and information so I figured it was worth a separate thread, so here goes.
    Execution:
    I made a bit of a poor decision back in June due to naiveness and impatience. I was out at Pismo with some friends for Huckfest. We stayed much later than anticipated and the our departure was just bad timing. High tide, a 9 foot wind swell, and the insane amount of snowmelt this year made the Arroyo Grande Creek more than just a creek. The net-net of it was I ended up hydrolocking the motor in my Tacoma...bad.
    I was fortunate enough to get towed off the beach by some friends. Five hours later, I got my truck started with nothing more than the basic hand tools I had in my truck. Literally MacGyvered some shit together, but I got it running. I didn't let it run for very long before realizing I had bigger problems then just getting the truck started. Judging by the oil leak and the gnarly audible knocking sounds from the bottom of the motor, I broke a connecting rod. I phoned a friend and my brother in law drove out early the next morning. I ended up renting a uhaul trailer to tow my Tacoma home.
    I called my insurance company after I got home. Told them exactly what happened, and, since I didn't collide with anything, they said the damage would be covered by comprehensive. The truck got towed to a repair shop and the adjusters did their things. After it being in the shop for a week, I made the executive decision to do the repair work myself. I didn't want the shop to do the work because of the nuances with my truck that would just take too long to explain. That and the labor was ridiculous. I could put that money to use on far better things than labor.
    Resurrection:
    In the time the truck was getting appraised and adjusted, I was doing my own research. I found a COMPLETE used motor out of Colorado with only 37,000 miles on it. As soon as my insurance company called me and said they sent the check, I bought the motor and started disassembly. Armed with a stack of papers from the FSM and an impact wrench, the teardown was not nearly as difficult as one might think. Hell I've never replaced a motor in my life before, but the FSM was damn clear. I had most of the tools needed to do the swap. I borrowed an engine hoist and stand from a friend and fellow TWer. I only needed to buy an engine load leveler and a 12mm hex key allen socket (but that was for the front diff...more on that later).
    I didn't realize exactly how fucked the motor was until I had it on the engine stand. Yeah, I broke a rod alright. Two to be exact. One blew a hole the size of my pinky clean through the side of the block and hence the oil leak. The other rod literally tore the crank cover like a piece of paper and almost punched a hole through the bottom of the pan. You would not believe the amount shit I found in the bottom of the pan. Believe it or not, I actually drove my truck from the street into the garage...on 4 cylinders.
    With the old motor out and the new motor on its way, I took advantage of the situation and the excess "labor" money and decided to regear my diffs to 4.56's.
    I ended up picking the motor up from the shipping terminal to save some money on home delivery. The new engine ended up being a great deal. Its super clean, carfax verified mileage, and the guys I got the motor from ended up changing a bunch of stuff on the engine before sending it out. Everything under the timing cover was brand new as well as the rear main seal. I bought a few other misc gaskets and seals, pilot bearing, and so on just cause it's a hell of a lot easier to change that stuff when the motor is out of the vehicle. I of course transferred my supercharger over. The engine I bought was from a prerunner so I also had to swap wiring harnesses and the oil pan from my old motor.
    After some late nights, countless beers and swear words, and a new Transmission jack, the engine was back in.
    I'd love to say that the SOB fired up the first shot. It didn't
    http://www.youtube.com/watch?v=JCG38sexpW4
    It eventually started but had zero throttle response and would not stay running. It would run for a couple seconds and then die. I hooked up my scan tool and I threw 8 different check engine lights. And they were all over the damn place. TPS, MAF, Coolant temp. None of it made any sense to me.
    I swapped throttle bodies with the one my new motor came with thinking maybe I fried the TPS with all the water I sucked in. Still, same problem. A little irritated, I walked away for a few minutes, came back and started looking things over. Found the number 1 plug on the ECU wasn't clicked in all the way. Pushed it in all the way, and, well....this was the second try:
    http://www.youtube.com/watch?v=XYM2v8CtgZo
    Redemption:
    Doing the engine work myself, I had some extra fun money. So I decided to put it to good use. I decided to ditch the midtravel kit up front and do the Total Chaos long travel kit to go with the LT rear I already have. No expense spared either. Coil bucket, camber tab, spindle and rear frame gussets. Spidertrax spacers to push out the rear to help compensate for the +7" wider front end. New black grill, headlights, blinkers, and devil horns. New high output alternator, new navi in the interior and of course, King coilovers. Only thing that I'm waiting now on are the King triple bypass secondary shocks. I have the shock hoops already, but I'm waiting on King to send out my bypasses before installing that bit. For now, I'm rolling without the secondaries.
    Well that's my story and I'm sticking to it. I'm headed back out to Pismo this weekend, exaclty two months since the shit hit the fan.
    And now for the cliff notes of the story.
  2. Aug 11, 2011 at 11:18 AM
    MartyMcfly
    MartyMcfly Time Traveler
    ROB
    Crapwater Floriduh
    15' 4runner Limited 4wd
    see Build page for details.
    Hydro-lock FTW!
  3. Aug 11, 2011 at 11:18 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Very nice job man! Looks great!
  4. Aug 11, 2011 at 11:19 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Sweet truck man! I liked the cliff notes at the end :laugh:
  5. Aug 11, 2011 at 12:40 PM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    wow!! best build yet! truck looks sick! X2 on the cliff notes hhaha
  6. Aug 11, 2011 at 1:19 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yeah, but as you are all too familiar with, it's not worth the stress. End result is great though.
    Thanks.
    The cliff notes were my way of laughing at the shitty situation. I shield myself with humor. :eek:
    This was more af a "re-build". The FULL build is here:
    http://www.tacomaworld.com/forum/1st-gen-builds/138220-jasons-long-travel-toy-taco.html
  7. Aug 11, 2011 at 1:25 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Great job!
  8. Aug 11, 2011 at 1:34 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Pretty damn good job. What kind of auto experience did you have before this?
  9. Aug 11, 2011 at 1:36 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot, Just Depends
    Cam
    Columbia,South Cakalacky
    05 PreRunner and 2001 Turbocharged Lexus IS300
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    X3 on the Cliff notes. (fuck yea was my fav :) ) well looks like its back with a vengeance! Good work man!
  10. Aug 11, 2011 at 1:54 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I gotta hand it to you-this is impressive! Rep to you for the effort putting it here too. I have done quite a bit of this stuff in my day but if this happened to me now-I wouldn't have the nerve you did to do such epic work. lol I played that "2nd start" vid a few times now and I love how at the beginning you go "sighhhhhhh-ok" because you've been through the hardcore circuit with this and it was down to the moment...priceless:) and that engine sounded golden right from coming off the starter. Well done.
  11. Aug 11, 2011 at 2:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I took auto shop in high school. Does that count?
    Nothing professional. Both my parents were mechanics and they owned their own smog/auto repair shop though much of my childhood. My dad used to make me do tune ups on all the shitty GM motors that gave only enough clearance for a 12 year olds hands to fit to get to the spark plugs. But helping them just taught me to keep track of what bolts went where.
    I've pretty much always done my own work/upgrades on my vehicles since I had a drivers license. It was out of necessity (I was poor). I've never removed an engine in my life before this ordeal. But as I said, the FSM was very descriptive. It was completley correct execpt for 1 wire which was just an engine ground on the oil pan. I know how to read and have an adequate amount of tools, so I decided to do it myself.
    In the end I did lose a 14mm open end wrench though. Still not sure where that ended up. :notsure:
    Thanks gents. Fuck yea FTW!
    :eek:
    Hell yeah. I was stoked when that thing fired up. It was like finally seeing the light at end of a very long dark tunnel. :D
  12. Aug 11, 2011 at 2:12 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Please.... PLEASE don't tell James this... He doesn't need anymore ideas lol.
    Looks great jberry!
  13. Aug 11, 2011 at 2:14 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    This is an epic thread, dude.
    Nice work!
    Fink
  14. Aug 11, 2011 at 3:04 PM
    Tacoma mud
    Tacoma mud Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    Where you get that front bumper??????????
  15. Aug 11, 2011 at 3:08 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Custom from Demello Offroad.
  16. Aug 11, 2011 at 3:19 PM
    ATriplett513
    ATriplett513 Well-Known Member
    Phoenix, AZ
    2011 Dbl Cb, 4x4, 4.0L, 6-speed
    How did your insurance pay for when you hydrolocked your engine off road?!? Shit I did that and I was 100% out of pocket. I got the part about you not hitting anything. My motor blew up 9k miles after I hydrolocked it on the way home from Target.
  17. Aug 11, 2011 at 3:25 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It wasn't considered "off road." I was in a California State Park and not in the OHV section. There's only one way in and one way out. :)
  18. Aug 11, 2011 at 3:34 PM
    ATriplett513
    Phoenix, AZ
    That is awesome man. Jealous, and it definitely looks like you put the money to good use. Congrats
  19. Aug 11, 2011 at 3:52 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    This is 100% awesomeness. I love the warning your truck has too when you start it. Great work with the resurrection and way to make lemonade out of lemons!
  20. Aug 11, 2011 at 5:50 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Wait...so no diesel and no snorkel?
    Come on!!!:D
