Exercised my 4wd mode today, heard a slight noice for a sec. Problems or normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rosebud, Aug 28, 2018.
  1. Aug 28, 2018 at 4:54 PM
    rosebud
    rosebud [OP] Love that transmission!
    SE Texas
    2017 TRD OR
    Stock suspension, stock wheels, stock bumper, stock, stock, stock, dammit!
    I read that you have to throw your truck into 4wd about once a month to keep everything working properly. I am not sure whether the previous owner did that. It was toyota certified, so I assume they checked everything.
    Today, I had a couple stretches of dry road with no turns, so I threw it into 4wd for a few miles on each. the second time I did, I heard a slight grinding sound for just a second at take off. The rest of the trip, it sounded and felt normal. What was the sound and is it normal?
    Edit: Mispelled NOISE in the title! Argh! :angrygirl::oops:
    lynyrd3 likes this.
  2. Aug 28, 2018 at 5:02 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I assume you were in 4Hi? Shouldn’t here any real noises on 4Hi normally but you will get some traction control noises in 4Lo and you should only be using 4Lo at very low (<5mph) speeds generally speaking
    rosebud[OP] likes this.
  3. Aug 28, 2018 at 5:10 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Never use 4x4 on dry pavement.
    ST77, e6400ultra and lynyrd3 like this.
  4. Aug 28, 2018 at 5:15 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    When I first got my truck brand new, it was a little "noisy" going in to 4H and 4L but "quiet" once engaged. After a few more times using it, it's all "smooth".
    So possible it may have not been used much, not at all, or used in quite a while. Just needed some use to get the oil in all the gears to be quiet again or ...
    Try it a few more times and see if you can replicate it. See which general area it seems to have come from.
    Lol Toyota Certified... checked everything.... :rofl::rofl::rofl: Sorry I don't have much faith in dealer service departments.
    lynyrd3 and rosebud[OP] like this.
  5. Aug 28, 2018 at 5:15 PM
    rosebud
    SE Texas
    2017 TRD OR
    I was in 4H. I have read that using 4wd high mode on dry road is okay as long as I don't turn. Is that not correct?
    tonered likes this.
  6. Aug 28, 2018 at 5:19 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    It is OK but I would only do that on long stretches of straight road never on turns. I did the once a month thing on pavement when I first got my rig but now almost every other weekend is some off road trip so that is where it gets used. Also, maybe the transfer case shifted into 4Hi right when you took off so that it kind of grinded?
    Dunno.
    tonered likes this.
  7. Aug 28, 2018 at 5:20 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Never assume! Also if you really do not need to,never throw it in 4 WD while moving including 4H .
  8. Aug 28, 2018 at 5:21 PM
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    So how do you drive in snowy weather.
  9. Aug 28, 2018 at 5:22 PM
    lynyrd3
    Bill
    When the snow is covering the road .
  10. Aug 28, 2018 at 5:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's no problem as long as turns are kept to a minimum.
    Quick... what's the difference between turning into your local mall in 4HI and turning the way your spotter tells you to turn on the slickrock on Moab trails when you are in 4LO?
    Answer: Slickrock has a much higher coefficient of adhesion than pavement so you will bind worse on the trail.
    OP, you are fine. Just keep from making really sharp turns. No big deal.
    SirWiggles, synaps3, su.b.rat and 6 others like this.
  11. Aug 28, 2018 at 5:25 PM
    poseytaco
    Nicholas
    Indiana
    2012 Off-road
    I didn’t read the post correctly. Didn’t see “dry pavement.” Still I couldn’t imagine 4H hurting anything on dry pavement other than wearing out you tires.
  12. Aug 28, 2018 at 5:29 PM
    rosebud
    SE Texas
    2017 TRD OR
    I wasn't moving when I put it in 4wd. I was at a stop sign, put it neutral, and drove without turns. I have read that you have to put it in 4wd once a month to keep everything lubed.
    hiPSI likes this.
  13. Aug 28, 2018 at 5:29 PM
    lynyrd3
    Bill
    When I started driving you had to stop the truck get out and lock your front hubs then engage the 4wd lever inside . No shift on the fly . That’s why I almost come to a stop if I can . Just don’t trust that shift on the fly over 10-15 mph .
    specter208 and chiefcrunchy like this.
  14. Aug 28, 2018 at 5:30 PM
    lynyrd3
    Bill
    Haven’t put mine in 4 WD since last winter
    Jukeboxx13, 2GSPointers and BSFord like this.
  15. Aug 28, 2018 at 5:32 PM
    lynyrd3
    Bill
    That’s fine ,you should be good doing it like that .
    rosebud[QUOTED][OP] likes this.
  16. Aug 28, 2018 at 5:34 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol it shifts just fine into 4WD at 50 mph. It's designed to do it and it has zero problems doing it. No noises, clunks, nothing.
  17. Aug 28, 2018 at 5:34 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Problem is the tcase, there’s no differential to compensate for things moving at different speeds and/or different directions. You can bind it up, and dicking up a tcase essentially dicks your transportation capability.
    rosebud[OP] and lynyrd3 like this.
  18. Aug 28, 2018 at 5:35 PM
    itsmermf
    itsmermf Well-Known Member
    Robert
    Merritt Island, FL
    2017 Tacoma TRD PRO
    Interior LEDs, all weather mats, TRD performance CAI, trifold hard tonneau cover, predator pro step, accessory interior/exterior illumination package. Kicker tweeters, Kicker speakers.
    When it’s raining, I’ll throw it in 4WD, for about 2 to 3 minutes at a time, shifting out and shifting back to 4WD, 2 cycles. That should be good.
    rosebud[OP] and BSFord like this.
  19. Aug 28, 2018 at 5:35 PM
    lynyrd3
    Bill
    I believe you but I ain’t doing it in my truck :D
    hiPSI[QUOTED] likes this.
  20. Aug 28, 2018 at 5:36 PM
    lynyrd3
    Bill
    Would never go over 45 in 4 H either but that’s just me !
