Exercising 4WD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Old Skol TRD, Sep 13, 2025 at 2:52 AM.
  1. Sep 13, 2025 at 2:52 AM
    Old Skol TRD
    Old Skol TRD [OP] New Member
    TRD Off Rodd MT-6
    Will driving 10 miles on pavement in a straight line in 4hi at 45mph once a month properly exercise my transfer case?.
    My only other alternative is to go to the beach but there are issues at times doing that. Dirt roads here are on private land secured with a gate
    SilverBulletII likes this.
  2. Sep 13, 2025 at 3:24 AM
    Tacoma Mike
    Southern Maine
    No problem.
    Would be better (IMHO) if you shifted to 4WD more often and run it a couple of miles. Exercising the actuators and forks keeps them happy..
  3. Sep 13, 2025 at 3:40 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    If yours is an off road as listed (?), then you should also exercise the rear locker actuator too. This can be done easily in a short parking lot or similar slow speed area without having to drive far.
    musicisevil and SilverBulletII like this.
  4. Sep 13, 2025 at 4:17 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    What’s the manual say?
  5. Sep 13, 2025 at 4:55 AM
    Fastbolt
    Fastbolt Active Member
    SW PA
    Underground 2025 Toyota Tacoma TRD Pro
    ReTrax Pro MX Bed Cover
    I believe that there was a similar post on this in the not to distant past. What I took away from it was that you could utilize the 4WD system on dry pavement so long as you did not make sharp turns. If you did make sharp turns, then you would feel the system seem to "jerk". Ask me how I know. I don't have my manual handy, but you may wish to check that section as it mentions engaging the system periodically. I normally engage the system at lower speeds, i.e., 35-50 mph. I have also done so on the interstate, but kept speeds at less than 60 mph. I did this on my 2005 Tacoma, 2011 Tundra, 2012 Tundra, and 2022 Tacoma, with no ill effects.
    tzukows and Chew like this.
  6. Sep 13, 2025 at 12:55 PM
    Tacoma SR-beast
    Tacoma SR-beast Member
    2021 Tacoma SR access cab 4x4 2.7L
    Stage 4 icon kit (upper control arms, added leaf springs, 2.5 remote resi in front, 2.0 remote resi in rear). C4 fabrication - hybrid front bumper W/ full sized bull bar (10K synthetic winch), rock runner high clearance rear bumper, C4 full skid plates (flat belly) and fuel tank skid, 16in method 703's wheels, 265/75R16 BFag KO3 tires, OTT -overland torque tuned (medium-spicy)
    Don't recommend using 4wd on dry pavement. The manual doesn't recommend doing that. Especially for 10miles at a time.
  7. Sep 13, 2025 at 1:03 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I like to put it in 4 Hi after a first rain (when roads tend to be slick) on a straight road.
    I also switch my Combo meter to a blank screen to remind me I'm in 4 Hi. Normally, I leave it showing MPG
  8. Sep 13, 2025 at 1:11 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This^^^^ .The OM says 10 miles a month in 4wd but slipping it into 4wd on a straight stretch a couple times a month for a couple miles is easier and probably better.
    tzukows and musicisevil like this.
  9. Sep 13, 2025 at 1:13 PM
    Bishop84
    Bishop84 Well-Known Member
    Works fine on pavement, its not made of pasta. Just use straight lines.
    If you're really worried find a gravel road or alley, no big deal.
  10. Sep 13, 2025 at 1:31 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Switch to 4 hi when there’s slack in the drive line. Let off the gas or switch to neutral. With all four wheels pointed straight, there’s nothing to worry about. It’s when you start making tight turns and the wheels rotate at different speeds while being unable to slip (like on gravel or ice) that strain is put on the drivetrain.
    Even 11, tzukows and Chew like this.
  11. Sep 13, 2025 at 1:38 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I run mine maybe 2 miles a month on a dirt road and lock the rear locker every third time and everything works every time. Seems the thing I always forget is the secret combination to put it in 4Lo and then lock the locker.
    tzukows likes this.
  12. Sep 13, 2025 at 1:38 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I have binded the drivetrain numerous times coming off the street to my driveway. Drove dry freeways in 4hi. It wont grenade.
  13. Sep 13, 2025 at 1:51 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    As an additional alternative to driving it in a straight line on pavement: Just engage 4WD right in your driveway a few times a month or even once a week. Switch it through 2H to 4H and 4L and back a couple of times to engage the actuators. Sometimes I switch the transmission into Neutral as well. I usually don't even move the truck during this exercise unless 4L gets cranky and won't let go back to 4H; a move of a few inches back or forward has always remedied it with nice clunk. The switch into and out of 4L always seems and sounds smoother after a couple of cycles like this.
    Inyo_man, tzukows and Sprig like this.
  14. Sep 13, 2025 at 2:36 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    In theory no. But I don't advise it. Where are you going to find 10 miles of straight road? The problem is getting distracted. forgetting, and making a right angle turn at an intersection, gas station or other location. Even if that happens, you're not going to have a catastrophic failure. Everyone I know has pulled off of a dirt road onto pavement and forgotten to disengage 4X4 and has driven a few miles before realizing it. Even driving off road you will find places where traction is good enough that you'll put the drivetrain in a bind.
    The transfer case is not really the problem. The part most likely to fail from non-use is the locking hubs. The lubricant on the hubs gets hard over time from non-use and won't allow the hubs to engage. You can give them a workout in your driveway by engaging and disengaging without even moving. Or just moving back and forth a few feet in a straight line. This also helps keep electrical connections from corroding. I think you'd be better off doing something like this but make it a point to get it out for a good workout every few months.
    The damage is cumulative. The more miles you put on the 4X4 system in high traction areas the sooner you're going to wear out parts. It may be years down the road and it may be the next owner who pays for the damage. But parts will wear out sooner. You're going to get the drivetrain in a bind using it correctly and by mistake enough. I just don't advise taking unnecessary chances doing it by design.
    It doesn't have to be 10 miles, it doesn't have to be EVERY month and nobody said the 10 miles have to be all at once. The idea is to use it regularly. I've had 4X4 fail to engage a couple of times after not using it regularly back in the 1980's and 90's. But not since making a point to use it regularly. The shooting club that I belong to is about 1 mile down a gravel road. I engage 4X4 on my way in and out every time I go there. That gets me about 2 miles every couple of weeks most months. I may skip a month occasionally but make it a point not to skip 2 months. Other months I may get in 200-300 miles. Going archery hunting tomorrow. It's almost 20 miles down a Forest service road to where I park. I won't NEED 4x4 to get there but will get in 15ish miles tomorrow.
    bgavin likes this.
  15. Sep 13, 2025 at 3:00 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I concur, just driving one mile or so every now and then will do the trick. If you are hell bent on being literal and doing 10 miles all at once, then find a dirt roads somewhere.
  16. Sep 13, 2025 at 5:53 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Locking hubs??
  17. Sep 13, 2025 at 6:10 PM
    tzukows
    tzukows Well-Known Member
    2017 Tacoma TRD Off Road Double Cab 6 Speed Manual
    I've had various 4x4 since 1992. Always exercised the drive train a couple times a year.
    Rolling in a straight line (even slight curves).
    Winter time they got used a few times a season.
    But I would engage 4Hi, 4Lo. Axle lockers in 4Lo exercised too.
    Kept everything working like new!
  18. Sep 14, 2025 at 8:46 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Luckily I drive a mile and a half down one street to get to the freeway every morning. As soon as I turn onto that street, I click it into four high. I’m going to have to read up about the rear locker!
  19. Sep 15, 2025 at 8:59 AM
    rygarski
    rygarski Active Member
    Rob
    2021 SR5 with Trail Package
    my 4x4 needs some exercise. eeeesh
  20. Sep 15, 2025 at 9:52 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Oh how I wish we had locking hubs. Sadly this entire paragraph is from the 80's and 90's. No way to unlock the hubs on these trucks...and no grease to worry about getting hard. Just a couple actuators that are internally lubricated.
    Grey 2015 likes this.
