Exhaust Advice
Discussion in 'Performance and Tuning' started by Xbox1571, Aug 12, 2018.
  1. Aug 12, 2018 at 7:04 PM
    Xbox1571
    Xbox1571 [OP] Member
    Jackson
    2006 Black Tacoma 4WD
    Kinda new to the modding game... Was wondering if anybody had any experience with the Magnaflow off-road pro exhaust system and/or the Magnaflow direct-fit catalytic converters, and possibly how the two might work together... I have an 06' with a lot of small problems, one of those being an exhaust leak after my cat. wanted to fix this (duh) just seeking some advice.
  2. Aug 13, 2018 at 11:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do you have a 4 or 6 cylinder?
  3. Aug 13, 2018 at 11:57 AM
    Xbox1571
    Jackson
  4. Aug 13, 2018 at 1:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds like you are really contemplating the exhaust. On the cheaper side, why not just replace the donut Gasket?
    inwood customs likes this.
  5. Aug 13, 2018 at 1:44 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    A friend has the offroad catback. Thing sounds pretty mean down low in the RPM range. Gets a tad raspy in the higher ranges. I'm looking at the same, but its a few months out.
    This vid is a pretty fair representation of the sound (as played on my TV)
    https://www.youtube.com/watch?v=3ZYeWEuqbro
  6. Aug 17, 2018 at 9:01 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Your truck has 4 cats. Where is the leak? What are your goals? Where are you located?
  7. Aug 17, 2018 at 11:05 AM
    Xbox1571
    Jackson
    it is on the connection between the final cat and the pipe that leads to the muffler. Somehow the piece was bent so out of shape that I can't fix it. I just don't want my truck to sound like a lawn mower and some extra HP wouldn't hurt :) I'm in GA so I don't have to worry about any stupid emission laws
    @Roostfactor
  8. Aug 17, 2018 at 11:34 AM
    Roostfactor
    TX panhandle
