Exhaust compatibility for 2nd Gen's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fennywald, Jan 16, 2011.
  1. Jan 16, 2011 at 3:17 PM
    Fennywald
    Fennywald [OP] Betty Blue
    Virginia Beach, VA
    SR5 Tundra 4X4
    Ok, i prolly missed a write up on something like this so don't kill me... Just wondering if an exhaust that from a '05 or any second gen would be the same on a 2011? I'm wondering because right now i'm looking at buying a used flowmaster exhaust from an 07 double cab long bed and i have a 2011, so would it be compatible?
  2. Jan 16, 2011 at 3:20 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    As long as you have a long bed, I'm pretty sure it will fit. I just dropped off my stock exhaust off of my 2010 DCLB to a guy with a 2007 today. Do you know what brand the exhaust is?
  3. Jan 16, 2011 at 3:21 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    All the hangers are the same, but the dclb exhausts are slightly longer. I think around 10" longer.
  4. Jan 16, 2011 at 3:22 PM
    Fennywald
    Virginia Beach, VA
    SR5 Tundra 4X4
    yea that's what i'm thinking but i just want to make sure. craigslist doesn't take returns.
  5. Jan 16, 2011 at 3:33 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Should be the same, but you can also check flowmaster.com or magnaflow's website and check what their fit guide says.
  6. Jan 16, 2011 at 3:41 PM
    Fennywald
    Virginia Beach, VA
    SR5 Tundra 4X4
    You are right sir, i looked it up and there are only two part numbers used from 2005-2010 which i'm assuming one is for the long bed double cab and the other for the rest. I'm pretty sure the 2011 is the same even though it's not on the list yet. Thanks!
  7. Jan 16, 2011 at 6:00 PM
    larryde09
    Larry
    Rochester, NY
    Note: there's also a difference if it's a V6 or a 4-cyl. The V6 lead pipe (the pipe from the cat to the muffler) is about 6" longer than in the 4-cyl. The flowmaster cat-back package gives this extension to you, but the magnaflow does not...I have a 4-cyl and had to cut out this ~6" out of the lead pipe.
  8. Jan 17, 2011 at 5:13 AM
    Fennywald
    Virginia Beach, VA
    SR5 Tundra 4X4
    Yea the two part numbers i saw were for the V6, there were some other part numbers for 4 cyl but i wasn't counting those. So is it just different for the long bed? Or does it apply for the extended cab or double cab short bed?? All it says on the list is 'V6' or 'Prerunner V6'
  9. Jan 17, 2011 at 9:14 AM
    larryde09
    Larry
    Rochester, NY
    The total length of the acess cab and the double cab is the same. The extra space needed for the double cab takes up some of the bed space. Therefore, a double cab with a "short" bed is the same length as the access cab with the regular 6' bed. Therefore, the other part number is either for the regular cab or the long bed...I'm not sure if the frame is shortened or extended respectively.
