Exhaust drone and resonator use
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IRDCTACO, Nov 17, 2009.
  1. Nov 17, 2009 at 7:22 PM
    IRDCTACO
    IRDCTACO [OP] Well-Known Member
    Charleston SC
    07 IR DC
    Has anyone here experienced exhaust drone with an aftermarket exhaust AND installed a resonator after the fact that DIDN'T cure the drone? The reason I ask is that I bought a Dynomax cat back with the Ultra Flow muffler that sounds great except for when I'm cruising around town between 45-50mph. It's when the engine upshifts to 5th and the rpms drop to around 1300 that I get a head splitting drone from the exhaust.
    This is the only time it happens and yes, I know I can downshift to 4th but I'd rather just lose the drone. I wouldn't mind if the resonator makes the entire exhaust range more quiet so long as it takes away the drone too. I'd just hate to have to pay for a resonator and cut the pipe only to find out that it didn't affect the drone at all.
    Most of my google searches result in people recommending someone else try one for his or her drone problem yet I've yet to hear back from someone who purchased one and had it work specifically on the drone.
    UPDATE: Okay, so I bought an Aero Turbine AR25 because ourdealsrock.com had one for $45. Unfortunately for me, it didn't cure the drone. On a positive note, the entire rev range sounds better with it but when the automatic upshifts and lugs the engine, the exhaust booms big time. So as per Dynomax's "sound guarantee", I'll exchange the Ultraflo out for the Super Turbo.
    So since I've updated my situation I'll update my question out of curiosity.
    Is there anyone out there with an aftermarket exhaust AND an automatic transmission that doesn't have low RPM exhaust drone? If so, what exhaust do you have or what steps did you take to eliminate it?
    Final Update: I installed the Super Turbo muffler and it did not fix the problem. I do think the Super Turbo muffler sounds better and I prefer the way the engine responds with this muffler vs the Ultraflow but the drone still exists when the engine bogs due to the automatic transmission. I tried the new muffler with the resonator and it didn't make a difference at all. If I had a 6 speed then there wouldn't be any problems as I wouldn't let the engine bog like the auto does but until Toyota revises the gearing (worse mpg than auto) and fixes the rattling clutch/throw out bearings, I won't touch another one of their sticks. Sadly the stock exhaust is going back on this weekend.
  2. Nov 17, 2009 at 7:41 PM
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, OME Nitrocharger shocks and Dakar leafs, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, Leer shell, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
    I had success with adding a resonator to my exhaust setup. You will realize how loud it is once it is quited down a bit.
  3. Nov 17, 2009 at 7:45 PM
    IRDCTACO
    Charleston SC
    07 IR DC
    Hey thanks for the response. Did you have a specific speed and or rpm that it droned at or was your exhaust just too loud overall?
  4. Nov 17, 2009 at 7:48 PM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    Is your exhaust dumped and do you have an intake? I have the 40 series Flowmaster and K&N intake and mine is dumped. Mine is a 6-spd and I never have any drone. It sure growls and sounds amazing. I guess being an automatic really can hurt trying to eliminate that.
  5. Nov 17, 2009 at 7:52 PM
    TorenApart
    I added the resonator because of a slight drone that after a while became annoying. I noticed it mostly during acceleration and shifting between 2nd and 3rd.
    Now having the resonator, I appreciate the over quieter exhaust note that still sounds pretty darn aggressive when you step on it. Don't get me wrong though, it is louder than stock still.
  6. Nov 17, 2009 at 7:55 PM
    dktaco
    Josh
    Instead of the resonator why didn't you just change the muffler? You could have easily gone to bigger muffler to lower the tone and drone!
  7. Nov 17, 2009 at 8:01 PM
    IRDCTACO
    Charleston SC
    07 IR DC
    That's exactly what I wanted to hear. What size/brand resonator did you use and where did you install it?
    The exhaust exits the rear passenger side exactly where the factory exhaust exits. The Dynomax has a great deep tone but when the engine lugs at 1300rpm in 5th it is just way too loud. The only way to get rid of it is to shift to 4th untill 50+ mph.
    The ultra flow came with the cat back kit but Dynomax has offered to swap out that for a super turbo but I like the fact that the ultra flow is stainless steel.
  8. Nov 17, 2009 at 8:36 PM
    TorenApart
    I realize that. I like the performance gain of Aero Turbine. It was also very cheap to add the resonator. ~$50 installed.
    I went with the Aero Turbine resonator (AR25). I had it welded in at a local hole in the wall muffler shop for about $15.
  9. Nov 17, 2009 at 8:47 PM
    Abe Froman
    Abe Froman The Sausage King of Chicago
    Fayetteville, NC
    2023 SR DCSB 4x4, White
    I've been struggling with this issue for a long time. You're right - there really isn't mush definitive info on fixing exhaust drone. I ended up ordering a Vibrant resonator and it just arrived. I'll have it installed this week and report back.
  10. Nov 17, 2009 at 8:51 PM
    IRDCTACO
    Charleston SC
    07 IR DC
    Thanks a bunch guys. I'll check out both the vibrant and the aero resonators.
  11. Nov 19, 2009 at 8:08 PM
    IRDCTACO
    Charleston SC
    07 IR DC
    Just wondering if you installed the vibrant yet? Also did you opt for their regular resonator or the ultra quiet resonator? I'm still torn between the ultra quiet and the Aero AR25.
  12. Nov 20, 2009 at 8:40 AM
    Abe Froman
    Fayetteville, NC
  13. Nov 20, 2009 at 9:27 AM
    Abe Froman
    Fayetteville, NC
    My drone is 2500-3000 rpm. Climbing hills with the engine in that range is head splitting. (running K&N CAI, DTLTs & Magnaflow cat-back) I really hope this resonator tones it down. I'll keep you posted
  14. Nov 20, 2009 at 11:35 AM
    IRDCTACO
    Charleston SC
    07 IR DC
    Thanks man. Let me know how it works out.
  15. Nov 21, 2009 at 6:41 AM
    dktaco
    Josh
    Well, the drone is coming from the DTLT's! This is happening because you opened up the flow of exhaust right from the engine.
  16. Nov 27, 2009 at 3:46 PM
    IRDCTACO
    Charleston SC
    07 IR DC
    bump for update
  17. Nov 27, 2009 at 4:17 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    My dad has the Gibson cat back on his 07 and it doesn't drone like that. I just purchased mine and will let you know when I get it in how it sounds in the low and high rpm range.
  18. Nov 27, 2009 at 5:15 PM
    IRDCTACO
    Charleston SC
    07 IR DC
    Do you both have V6 automatics?
  19. Nov 27, 2009 at 6:23 PM
    Masada
    Taylor
    Laveen, AZ
    Yes to the V6 and he has the auto and I have the manual...
  20. Nov 28, 2009 at 8:03 AM
    IRDCTACO
    Charleston SC
    07 IR DC
    Well, there goes that theory. I wonder if it's just the nature of a straight through exhaust? The Ultraflo isn't really much different from the resonator I bought other than the fact that it's fatter. Hopefully the Super Turbo will fix everything. Thanks for the help everyone.
