Exhaust experience needed...
Discussion in 'Performance and Tuning' started by roxspin72, Dec 20, 2008.
  1. Dec 20, 2008 at 4:01 PM
    roxspin72
    roxspin72 [OP] Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Ok so I was bored off my ass today, and I decided to mess around with my Exh. Been hearing about a bunch of folks dumping the outlet right after the axel. I wanted to do this for a while. Felt getting rid of that 4"stainless tip on the right side would bring a new look. And it did, looks real clean.
    But, before I cut anything I experimented by just unbolting the tail pipe after the exhaust. Sounds good actually. Very deep, same rumble, and it is a bit more quite when just cruising. Im very happy with the sound. I would make a sound clip but will be getting my DT Long tubes, and also planning on a resonator to add, so I'll wait til then.
    Question #1;
    I want to run it like above set up, oh; but will add a turndown so the exhaust aint going straight out torwards the spare.
    But does anyone think that loosing this 3 foot section of piping will affect needed backpressure and in the long run HP??? (Note: the DT's already loose the front cats so my set up will be DT's/Y-pipe/borla w/resonator dumped out at the axel. What you all think???
    Question #2;
    Dont really know anything about Resonators, but Im thinking this will tone down the noise increase that will come from running no cats. But, do they add back pressure? Anybody got any better recommendations???
    Thanks...
  2. Dec 20, 2008 at 4:04 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    so ur saying that you un bolted the portion of Stainless steel pipe mounted after the muffler?
  3. Dec 20, 2008 at 4:05 PM
    roxspin72
    NC
    Oh Yeah!!!
    Yeah for now. I will probably cut where that turns down and bolt back on.
  4. Dec 20, 2008 at 4:07 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    are you runnin cats?? Could i do the same with my 08 reg cabs stock exhaust?
  5. Dec 20, 2008 at 4:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "Back pressure" is not an issue on modern exhaust systems. "Scavenging" is much more important. Dumping right after the muffler shouldnt hurt anything, niether will adding a resonator. You should mount the resonator close to the muffler, then keep about 1 foot of pipe after that.
  6. Dec 20, 2008 at 4:28 PM
    roxspin72
    NC
    Oh Yeah!!!
    Got my front ones on right now. Will have none after the Longtubes are on. Guess you could do it. But I would do a temporary trial to make sure it's what your're looking for in sound.
    Hey thanks chris. I know you done different exhaust set up's, so your word is enough to set me at ease with this plan.
    Will any resonator just muffle sound, or are some meant for different puposes? Need one small enough to fit between flange and muffler.
  7. Dec 20, 2008 at 4:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Resonators have different applications, but your local muffler shop should have the right one for ya.
  8. Dec 20, 2008 at 4:39 PM
    roxspin72
    NC
    Oh Yeah!!!
    Cool, thanks again...
