Exhaust Flange Bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by KingToaster, Jul 13, 2012.
  1. Jul 13, 2012 at 8:24 AM
    KingToaster
    KingToaster [OP] Member
    Alan
    NH
    2002 Tacoma DC 3.4L SR5
    Deck Plate w/ K&N. Grey Wire Mod.
    I have a '02 3.4L Double Cab. Both of the exhaust gaskets are going bad, one is pretty much gone I think and there is an exhaust leak that seems to be getting worse by the day because of it. Question is i know sometimes the flange bolts can actually be studs. They looks like a normal nut and bolt but i can't tell because they are pretty much rusted through (NH winters will do that). I looked online and can't seem to find an answer. I was going to just break the current ones free and replace with SS bolts. Any one see an issue with this solution. I did see a video online of some guy replacing from the cat back and he had bolts but just wanted to confirm. Thanks.
  2. Jul 13, 2012 at 8:38 AM
    scocar
    scocar Patron of the Farts
    Just looked at mine. Clearly nut and bolt.
  3. Jul 13, 2012 at 10:47 AM
    KingToaster
    Alan
    NH
    Thanks, at this point it has all melded into one piece of rusty metal. Thanks again. Should be fun getting them off.
  4. Jul 13, 2012 at 10:51 AM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Mine are nut and bolt, although I have an 06 haha. I replaced mine with better hardware.
  5. Jul 13, 2012 at 10:55 AM
    scocar
    When you say both, do you mean before and after cat? Maybe just cut off the pipes and clamp on new material?
    Maybe try using a sawzall or angle grinder to cut the bolt head and nut off, then heat up the remaining bolt shank with a torch and drive it out with a punch? Assuming the flange itself is not so rotted that you won't ever get a good seal with it.
  6. Jul 13, 2012 at 11:08 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I would like this answer as well. I have a very similar issue with my 08'. When I broke the studs removing them I drilled the hole out and put in grade 8 nuts/bolts/washers I had in my spare parts bin. Once side now leaks even though they are torqued to all hell and I used new gaskets.
    I assume my issue is related to the nut/bolt/washers not expanding and contracting at the same rate as the flange.
    I would be hesitant to throw any old bolt in there until someone on here that is a pro can comment further. I have my 2nd set of new gaskets ready and as soon as we get this answer I can finally stop the leak I have that's driving me crazy
    :popcorn:
  7. Jul 14, 2012 at 11:44 AM
    FFRG1990
    FFRG1990 Member
    Rob
    Pollock Pines
    04 TRD 4x4
    2in lift rock sliders gnarly bumper
    make sure before you replace the gaskets to check the muffler bearings, they can cause issues later
  8. Jul 14, 2012 at 12:01 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Just wanted to be sure you are talking about manifold flange to downpipe. Not sure if nut n bolt or if stud and nut. But if you replace with nut and bolt, be sure to use lock washers. Grade 8 is fine and so is stainless. These fasteners should not be more than snug tight, at least enough to flatten the lock washers. If you over tighten, your gasket will fail sooner.
    The thing with the bolts is that they need to be able to withstand extremely high heat. You can talk to the professional bolt guys at fastenal, or you can take my word that grade 8 or stainless will be fine. As before, overtightening exhaust fasteners will lead to premature failure of your gasket material. Use lockwashers to keep things together better.
  9. Jul 18, 2012 at 9:02 AM
    KingToaster
    Alan
    NH
    Basically I am looking to replace the Gaskets on both sides of the second Cat. Not the exhaust manifold. I think I will be working on it this weekend as well as replacing a bad u-joint. I grabbed some SS hardware with lock washers so lets hope it does the trick.
  10. Jul 26, 2012 at 10:25 AM
    KingToaster
    Alan
    NH
    Did this finally over the weekend. it was standard nut and bolt (or at least used to be) had to grind down the bolt heads to the flange and punch them out. replaced both gaskets and upgraded to SS hardware. no more exhaust leaks.
    TreeFortRichard likes this.
