Exhaust flange gasket question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by glennv, Jun 25, 2025.
  1. Jun 25, 2025 at 11:31 AM
    glennv
    glennv [OP] Well-Known Member
    I need to replace the gasket(s) on the passagenger side between the manifold and exhaust. Is there a donut and gasket in there. Anyone have the part numbers?
  2. Jun 25, 2025 at 1:04 PM
    zguy1
    zguy1 Well-Known Member
    Midwest
    On the V6 there is. I don’t have the part number but it was easy to get from my local dealer.
  3. Jun 25, 2025 at 1:11 PM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Just did this the other day. It's a smaller cylinder ring type gasket compared to the bigger thicker donut style that goes to the muffler section with the spring clamps.
    I used https://www.amazon.com/dp/B000EPPF2Y?ref=ppx_yo2ov_dt_b_fed_asin_title its not actually green and Autozone had it in stock as well for a bit more.
    There are 3 total. One from each manifold to their secondary cats, and a second one on the passenger side where the two secondary cats merge. I had to replace both passenger side ones as when I was trying to replace just one the upstream one crumbled into pieces so may be a good idea to get at least 2 and if you have rust new bolts may be necessary.
    OEM the gaskets were a lot more expensive and shows two different part numbers but they seem to be identical and the felpro one lists fitment for both, and worked fine.
  4. Jun 26, 2025 at 3:59 AM
    glennv
    Awesome. One it is. That's the only one O'Reilly said I needed but it looks smaller than whats in there now. Must bw the rust and caked on mud.
    Thanks
    Peter603Taco[QUOTED] likes this.
  5. Jun 26, 2025 at 5:58 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Yeah no prob, I thought the same thing it looks too small but fit like a glove. It kind of sits more on the ID of the flange it doesn't protrude all the way to the outside, it'll make sense once you see it.
