Exhaust fumes inside truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danbrooks1957, Dec 1, 2017.
  1. Dec 1, 2017 at 2:01 PM
    danbrooks1957
    danbrooks1957 [OP] New Member
    Dan
    2013 toyota tacoma (base)
    none
    Hello everyone,
    Dan here and I'm new to the site. I have a 2013 Tacoma base, 4 cylinder automatic and the truck sits quite a bit sometimes for months on end.
    A few weeks ago I took it out as I had to drive down to Pittsburgh to pick something up that would not fit in my Yaris,(imagine that right!). As I'm going down the road with the heater on I smell fumes pretty bad coming out of the heater vents. The smell persisted throughout the whole trip enough to where I had to drive with the window open quite a bit for the whole trip.
    Any ideas as to what to look for? I don't smell anything outside the truck and it doesn't sound loud as in an exhaust leak. the truck only has 40k on it.
    Any suggestions as to what to look would for be helpful versus taking it to the dealer and them charging me a thousand dollars for nothing.
    Thanks,
    Dan.
  2. Dec 1, 2017 at 2:07 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    No damn idea
  3. Dec 1, 2017 at 2:26 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Muffler bearing!! Sorry man, had to..
  4. Dec 1, 2017 at 5:38 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Check your cab filter for 'stuff'. Was the recirc button on or off?
  5. Dec 1, 2017 at 5:43 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you sure it's not rodent urine?
    Pretty common for mice to take up residence in unused vehicles.
    DanoDavis likes this.
  6. Dec 1, 2017 at 6:50 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Perhaps the old banana in the tailpipe trick?...
    (On a serious note, in addition to the above suggestions, i'd look under the hood for something dripping onto something that gets hot)
  7. Dec 2, 2017 at 5:35 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sitting for months...
    Rat / Mouse in vent filter.
    ChadsPride likes this.
  8. Dec 2, 2017 at 9:30 AM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    If it is truly exhaust fumes, here is the order in which I would go through the rig to look for a leak.
    While cold, start the engine and use a lighter/flame or something that will smoke ( incense,sage, greasy rag...) and use it to around the exhaust manifold. If there is a leak the smoke will move in and out (if the leak is big enough) flame will do the same. if nothing, check the collector mount with the same procedure, on down the pipe inspecting every joint or connection.
    one thing you did not mention is the exhaust pipe dump location, is it in the same spot as stock or is it a straight run right under the bumper?
    straight pipe out the tail is known to leak into the cab as the fumes are picked up by the vortex that is created from the air flow over the cab and into the bed. The newer ram trucks have a modified exhaust/bumper configuration that reduces/eliminates this.
    You may just have stench from animals and stuff as mentioned above.
    there have been things like cracked exhaust manifolds on the 4 cylinder engines that don't reveal themselves until hot.
    cruxofthebisquit likes this.
  9. Dec 8, 2017 at 11:20 AM
    WPDAWG11
    WPDAWG11 Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    OP did you ever figure this out? I just changed my valve cover gasket, the job was easy. But right after I noticed exhaust coming in when the heat is running and I am at idle. Any ideas TW?
    Man I haven't logged in a while lol
  10. Dec 8, 2017 at 12:08 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    How bout them Dawgs! I haven't been this excited since 1980.
  11. Dec 8, 2017 at 12:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A lot of times it's an oil leak making it onto the exhaust that you smell. Check the valve cover gaskets, see if it is leaking on the ex manifold.
    blu92in99 likes this.
  12. Dec 8, 2017 at 1:00 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    if its coming from the heater vents, the fumes must be coming in from the intake under the wiper blades located on the cowl. this is where all air is taken into the HVAC for heating or cooling
  13. Dec 9, 2017 at 10:50 AM
    danbrooks1957
    Dan
    none
    Sure haven't! looked the truck over and don't see anything out of the ordinary. It's setting in the garage for now. Like I said before it sets quite a bit, that in itself might be the problem. I have a Yaris I drive daily and am saving the truck for when I retire to North Carolina. Let me know if you figure it out, Dan.
  14. Dec 11, 2017 at 10:33 AM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    I'm very pumped to be as far along as we are. Anything else is icing. Still pumped about getting rid of Mark for Kirby!
    I changed my valve cover gasket and then this smell of fresh exhaust when the heaters on started occurring.
    Nice, will do dan.
  15. Dec 11, 2017 at 1:26 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This is what I'm thinking. Considering the life this truck lives, it's possible the cats are clogged... would probably not be the sole cause of exhaust fumes but might be a contributing factor.
