Exhaust, headers, and CAI
Discussion in 'Performance and Tuning' started by tbkfan, May 5, 2014.
  1. May 5, 2014 at 11:52 AM
    tbkfan
    tbkfan [OP] Active Member
    2011 Tacoma TRD Sport 4X4 Double Cab 5A
    I'm looking to boost the performance of my 2012 TRD DC. I have been talking to a local performance tuning shop and they want to sell me the following:
    1. Gibson exhaust
    2. JBA headers
    3. Air Raid CAI
    4. Air Raid throttle body spacer
    5. Bully Dog computer system
    I know for sure that I am out on the JBA headers. There is definitely enough negative said about those on these and other forums. Sounds like Doug Thorley is the way to go there. Few questions about headers... Will they make the truck quite a bit louder? Inside the cab? Cruising speed? Or is it just when you really step on it?
    For the exhaust, I'm leaving towards getting the dealer to install TRD setup since the price is the same and from what I'm reading it's a toss up between it and the Gibson. Is there a dual exhaust option out there that would give me even better performance? I'm in Canada where I don't have to pass regular emissions tests by the way...
    For CAI, I am definitely among the skeptics. I only consider it because they're telling me it is a key component of their 5 step system for getting the maximum performance. I'd rather not have to fuss with cleaning and oiling a filter, but if it is going to make the rest of the system work as designed I would go with it.
    Throttle body spacers, I know nothing about.
    And I think that the Bully Dog computer is a no-brainer. Am I wrong?
    Last question: can anyone recommend a shop in Calgary that can be trusted to this kind of work?
  2. May 5, 2014 at 11:17 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    1. Any catback will do. Just whether or not you like the way it sounds.
    2. URD Long Tubes & Y pipe.(it will make your truck alot louder may have to also install a vibrant resonator as well to cut down on the rasp) OR if u have to do emission checks then you could do JBA shorties.
    3. Stock air box is a cold air intake but if you want to change the underhood appearance then I'd go with a AFE Stage 2.
    4. Throttle body spacer is junk DO NOT BUY THIS.
    5. The bully dog programmer has NOT be confirmed it gives any real performance. I'd shy away from it until we get some hard facts about whether it works or not.
    In the grand scheme of things if you want more performance out of your truck your going to have to go forced induction. These mods I listed will get you small gains but like I said if you want more than a 15-20hp bump then your gonna have to pony up some bucks for a little boost.
  3. May 5, 2014 at 11:18 PM
    double dee
    double dee Well-Known Member
    Arizona
    Supercharger :D
  4. May 5, 2014 at 11:39 PM
    Aztecs
    Aztecs Well-Known Member
    Jose
    Goodyear, Arizona
    2012 DCLB V6 4x4 SR5
    Debadge, Tailgate lock, 3" ProComp Suspension Lift, ProComp wheels and tires, Volant CAI with ram air scoop.
    I bought the Volant CAI with the under the hood ram air scoop, get rid of that charcoal filter. For the Headers, do you want More Torque Gain or HP gain. Long Tubes for your get up and go gain or go with short tubes for better HP and maybe better MPG at Highway speeds. All depends on your driving style, but deffinitely go with Doug Thorley. I also have a 2012 and JBA doesn't advertise headers for our year truck since the header design is different on 2012's and newer. I had to call Doug Thorley main office in California to get the Part number for the 2012 Headers since it doesn't pop up on their website. Personaly I would skip the throttle boby spacer. I don't believe they work on a fuel injected engine unless someone can prove it to me with a Dyno test. For the exhaust, I would just get the TRD exhaust unless you want to go custom. For the computer, I would say NAH! I would rather spend my money on the supercharger.
  5. May 6, 2014 at 5:50 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Any shop that is recommending 4 & 5 as a part of a "performance" upgrade would make me go somewhere else. Neither of those has shown any gains on an NA 4.0, and if they are recommending them, they are after your $$$ more then perf.
    If you want to stay NA, try:
    - a URD or AFE CAI
    - URD MAF Cali
    - headers (LT or ST, depending on whether you want to optimize high-end HP or low-mid TQ, respectively)
    - URD Y-pipe
    - 3" catback (if you want to optimize high-end HP) or just a drop in muffler and resonator as needed
  6. Jun 26, 2014 at 1:23 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    1. Long tube headers seam the best.
    2. CAI or better filter and intake mods, I think the factory intake is good.
    3. Replace the muffler with stock exhaust or 2 1/2" cat back.
    4. If you do a cat back you will loose bottom end HP so add the intake spacer to add low power back, the CAI, cat back and spacer all work together great...
    5. A good Performance chip will help but I don't know if one is proven and you would need dyno tuning to maximizes the HP...
    6. A good y pipe helps top end, not sure about low end power... No one has tested a full system that I have seen....
    7. PVC delete, the pvc sucks oil into the intake and is bad for the engine, some guys run a catch can which makes no sense just delete it.
    8. 170 thermostat, but may need a tuner to maximize.
    After any mod reset the computer so it can learn the mods....
  7. Jun 26, 2014 at 2:04 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    You nailed it.
    Even the throttle body spacer alone would be a deal breaker for me.
    Between long tube and short tube, I'd recommend going long as bottom end torque is way more useful on a truck than top end horsepower. The equal length URD long tubes are brilliant works of header design.
    I'd like to get them and I don't even have a 4.0! :laugh:
    If you only do ONE mod... do headers. They are by far the best bang for your buck, because they improve the operating characteristics of your engine even if you don't change anything else. :thumbsup:
    Greg
  8. Jun 26, 2014 at 4:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Lucario Runner and I did before and after dyno's with the URD Y-pipe. Being that his is an automatic, couldn't start below 3k RPMs. It did make a substantial increase on the graph. For the RPMs which were tested. Link with his dyno's is in my Sig.
  9. Jun 26, 2014 at 4:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Jun 30, 2014 at 9:37 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    All trucks/cars are different for what performance mods work best... That so called performane shop needs to do there homework for 2nd generation tacomas...:rolleyes: You will get way more power from an aftermarket y pipe vs a new muffler/catback exhaust... especially if you are 4X4... My SS JBA headers are great;)
  11. Jan 5, 2015 at 12:17 AM
    Yota64
    Yota64 Professional Threadjacker
    One of you says LT is for high end HP and ST is for low end TQ, and the other says opposite. What's the deal?
    Question, of the mods listed, some are said to do nothing. Would the gains be the same without those? For example, the catback and especially the CAI. If I were to buy this I would lean towards selling those.
  12. Jan 5, 2015 at 5:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not exactly sure what you mean? If you were to buy the whole package, you would then sell the catback and intake?
    Is that what you mean?
    If it is then just but the pieces individually, and not spend that extra cash. However, the intake will gain you an increase in power. The catback all depends on what you have done before it, to help the engine breathe in/out. Sum of the parts is greater than the individual part.
  13. Jan 5, 2015 at 8:22 AM
    Softtacosupreme
    Softtacosupreme Well-Known Member
  14. Jan 6, 2015 at 11:18 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Depends on which engine you have. For the 4.0, ST = better low end, LT = better high end. For the 4-cyl, and just about any other engine out there, the opposite is true, LT = low end, ST = high end.
    Now the URD equal length are totally different animals, supposed to act more like LTs for any other engine.
  15. Jan 6, 2015 at 11:26 AM
    Yota64
    Only because I have heard they do nothing. And it says the package is cheaper than buying them individually, so you probably wouldn't want to do that either? But I understand what you're saying, they need to be used in conjuction with the other parts to reach their potential.
    So it says about 50 HP gain. I wonder where this would put your MPG? More or less? I assume less.
    That is confusing! Why is it reversed between engines?
  16. Jan 6, 2015 at 1:24 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I agree with Lurkin :thumbsup: My thoughts is that the exhaust pulse plays a factor between a 6 cylinder and 4 cylinder.
  17. Jan 6, 2015 at 1:30 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I think the shop you are going to right now is not worth your time if they are recommending those mods. Save up and get a S/C installed at Cochrane Toyota. They usually have the best price in Alberta and then you'll have a power increase you can notice.
    My local custom shop has been good to work with, but that's because they are a small town shop that focuses on light trucks and relies on repeat business.
  18. Jan 7, 2015 at 6:03 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I believe its mostly due to the tube sizes and lengths, along with the collector size. Some design considerations were given due to packaging the pipes in the stock bay. For example, the URD equal length headers need to run through the steering linkage.
