Exhaust heat shield removal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patchesj, Apr 7, 2018.
  1. Apr 7, 2018 at 1:49 AM
    patchesj
    patchesj [OP] Well-Known Member
    My 2010 DCSB Off Road has some miles on it.. The waffle type heat shield material that is attached to the underside of the cab has basically become completely detached from the mounting posts. It's barely hanging onto the truck. Given the distances from the exhaust piping up to the shields, I can't see how these things are really that critical. Specifically, I'm talking about the 2 shield pieces from around the transfer case on back, after it is just one pipe on the passenger side. I'm trying to decide if I can:
    A) Just pull the shields out
    B) Should try to reattach them somehow
    C) Spend a weekend trying to remove them, clean up the mounting posts, remove all fasteners, get all new parts, put new shields on
  2. Apr 7, 2018 at 5:03 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Nothing scientific here, but any heat I can prevent from making its way into my truck on a hot Texas day is a good thing.
    I’d suggest C, with a temporary B.
  3. Apr 7, 2018 at 5:11 AM
    DrFunker
    DrFunker Well-Known Member
    Just reattached mine the other day.
    Fender washers and metal zip ties FTW. :thumbsup:
    CMD-KY likes this.
  4. Jun 11, 2018 at 11:33 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Mine is starting to rattle also. Does anyone know the bolt size for the existing stud? I have a feeling that if I try to remove the existing nut it will break the stud clean off the body.
  5. Nov 29, 2018 at 5:18 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    How do you even take it off? Mine got some dirt stuck in it and made it rattle
