Exhaust help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BriBen69, Apr 7, 2015.
  1. Apr 7, 2015 at 9:26 AM
    BriBen69
    BriBen69 [OP] Member
    Need to get a new muffler for inspection as mine has three decent sized holes in it. Looking to buy a used stock from a user on here. He has a '13 and I have an '06. I thought I read on here somewhere that they had changed a hanger location or two in the 12 model but search isn't giving me anything. Anyone know if this is true or not?
  2. Apr 7, 2015 at 11:30 AM
    BriBen69
  3. Apr 7, 2015 at 12:58 PM
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
    they changed it in 2013. the difference is the rear hanger bent 90 degrees. i bent mine with a torch and a floor jack handle
  4. Apr 7, 2015 at 3:14 PM
    BriBen69
    awesome thanks for the replies. ill have to try bending it but if i break it i guess i can always dump it after the rear axle
  5. May 5, 2015 at 10:58 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Do you have any pictures of the difference between the two?
    If I were to dump the exhaust after the rear axle, would the rear hanger even be an issue(doesn't it come after that portion of the exhaust?)
    The reason for the questions is that I'm contemplating bolting up a stock 2014 DCSB Exhaust to my 2008 DCSB.
  6. May 5, 2015 at 11:33 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    The rear hanger or hangers are different.You would have modify one or both of them to work.
  7. May 5, 2015 at 12:22 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Ok gotcha. What about where the exhaust bolts up...is that pretty straight forward?
    Is there some sort of gasket that goes in between the two pieces to ensure a snug fit or to alleviate a leak?
