Exhaust Installation Help
Discussion in 'Technical Chat' started by Nick54, Oct 24, 2011.
  1. Oct 24, 2011 at 4:18 PM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I am going to be installing an aFe catback soon and was wondering if anyone could tell me the correct way to make up the flange where the cat out connects to the muffler inlet pipe (flange with the spring nuts and bolts). Is it a torque or compressing the springs to a certain length ?????
  2. Oct 24, 2011 at 5:43 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Torqued, but i'll be damned if I can remember the # right now. I want to say its something like 42-44?
  3. Oct 24, 2011 at 5:45 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    eh, I stand corrected:
    INSTALLATION
    1. INSTALL EXHAUST PIPE ASSEMBLY FRONT
    (a) Install a new gasket onto the exhaust manifold RH. (b) Install the exhaust front pipe with the new 2 nuts.
    Torque: 62 N*m (632 kgf*cm, 46 ft.*lbf)
    2. INSTALL EXHAUST FRONT PIPE ASSEMBLY NO.2
    (a) Install a new gasket onto the exhaust manifold LH. (b) Install a new gasket onto the exhaust front pipe. (c) Install the exhaust front pipe No. 2 onto the
    insulator. (d) Install the exhaust front pipe No. 2 onto the exhaust
    manifold LH with the new 2 nuts.
    (e) Install the exhaust front pipe No. 2 onto the exhaust front pipe with the 2 bolts and 2 nuts. Torque: 48 N*m (489 kgf*cm, 35 ft.*lbf)
    (f) Install a new gasket onto the exhaust front pipe No. 2.
    (1) Using a wooden block and plastic- faced hammer, tap in a new gasket until it is flush with the exhaust front pipe No. 2. NOTICE: • Make sure that the gasket is in the
    correct direction when installing. • Do not reuse the removed gasket.
    3. INSTALL EXHAUST PIPE ASSEMBLY CENTER
    (a) Check the free length. (1) Using vernier calipers, measure the free length
    of the compression spring.
    Minimum: 40.5 mm (1.594 in.)
    If the free length is less than the minimum,
    replace the compression spring. (b) Install the exhaust tail pipe onto the 4 insulators. (c) Install the exhaust pipe center onto the exhaust
    front pipe No. 2 with the 2 bolts and 2 springs.
    Torque: 43 N*m (438 kgf*cm, 32 ft.*lbf) 4. INSTALL HEATED OXYGEN SENSOR (See page EC-
    19)
    5. CONNECT CABLE TO NEGATIVE BATTERY TERMINAL
    Torque: 3.9 N*m (40 kgf*cm, 35 in.*lbf) 6. CHECK FOR EXHAUST GAS LEAKAGE
