Exhaust, Intake and Headers advice
Discussion in 'Performance and Tuning' started by pamantea, Mar 15, 2010.
  1. Jun 7, 2010 at 6:04 PM
    WRrider450
    WRrider450 Well-Known Member
    Torranceish
    09 TRD Off-Road 4x4
    13" Wicked Flow Muffler
    I have a Wicked Flow Muffler and it is great. i have the single tube but they also make double tubes as well
  2. Jun 10, 2010 at 4:09 PM
    pamantea
    pamantea [OP] Well-Known Member
    British Columbia, Canada
    TRD Exhaust
    Hey, I ended up going with the TRD exhaust and love it! I am now considering a TRD intake...but haven't made up my mind. One warrenty is up I will chip it I'm sure.
  3. Jun 10, 2010 at 4:45 PM
    PowTaco
    PowTaco Shred The Gnar
    The Beach Life
    Silver Surfer
    stock for now...more to come
    Well you definitely get a nice sound from the TRD, but not really any performance from it.
  4. Sep 22, 2010 at 3:53 PM
    pamantea
    TRD Exhaust
    Love the sound! Now I want to add a CAI and i guess the MAF calibrator. What will I gain? I know the website claims I'll claim 15rwhp from just the maf, but all together????
  5. Jan 15, 2012 at 1:50 PM
    Christianson.USMC
    Christianson.USMC WOUNED WARRIOR MARINE
    Will
    Jacksonville, NC
    2011 4wd Sport 4.0 sbed JBL Dcab,3'' lift etc
    TRD Intake, Borla exhaust,JBA long tube headers, DT Y Pipe, Light Racing UCA's, Jet Throttle Body spacer, lifted 3.5" front 3"back. Grill guard w/ KC lights, Stepsides, Tint, hood protector, window visors, Caltrend neopreme seat covers, weathertech mats, HID fog and headlights, 1" wheel spacers front .5 rear, brakelight guards,265/70/r17 till they die and can get 33's, more to come
    What about Borla cat back exhaust with a TRD intake topped witha AFE throttle body spacer???
  6. Jan 15, 2012 at 1:50 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Add a MAF calibrator instead of the TB spacer and call it good!
  7. Jan 15, 2012 at 2:33 PM
    Christianson.USMC
    Will
    Jacksonville, NC
    Sweet thx for the tips guys.
  8. Jan 15, 2012 at 3:59 PM
    Christianson.USMC
    Will
    Jacksonville, NC
    Mass air sensor? what is the difference or is there.
  9. Jan 15, 2012 at 7:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    One day, a friend of mine and had the oem intake off, and were curious to see what it looked like on the inside. Upon inspection, it was overly obvious that due to a plane that runs down the middle of the inside, the swirling effects induced by throttle body spacers would be completely negated. It would effectively straighten the air back out.
    It was very interesting to learn that. With that in mind, and my knowledge of what other aftermarket companies do for other motors, I came up with a way to make a spacer that does work. It is an intske manifold spacer that fits between the plastic upper intake plenum, and the lower aluminum plenum, which is bolted to the heads.
    I am sure a few member on here know of the other member who's screen name is Coupe.
    I went to him with my idea and dimensions. About a month later we had the first prototype. I still use it as well. The intake manifold spacer lengthens the primaries by a 1/2". Thus increasing torque throughout the power band. It also improves horsepower and gas mileage.
    My friend at NST, or Non Stop Tuning, now sells them to the public. They also have the dyno charts to prove the results.
    www.nonstoptuning.com
  10. Jan 16, 2012 at 9:04 PM
    clcoyle
    clcoyle Well-Known Member
    Interesting stuff
  11. Jan 16, 2012 at 9:09 PM
    08pretaco
    az
    Dont see a dyno graph posted anywhere.
  12. Jan 17, 2012 at 8:39 AM
    Christianson.USMC
    Will
    Jacksonville, NC
    So throttle body spacers are not worth it do you think they take away power i have had them in the past and they DO give a more aggressive sound. If i were to get one then you think it would just be for sound and looks then? I have heard things like Mass air flow sensors and such are those a good idea with intakes and exhaust. There is a nother thing that people have talked about that has to do with induction, but cannot find it maybe they are calling it by slang?
  13. Jan 17, 2012 at 9:04 AM
    Christianson.USMC
    Will
    Jacksonville, NC
    What is the difference between the the two and which would you reccomend and and do you have any links to both.
  14. Jan 17, 2012 at 9:08 AM
    08pretaco
    az
    Well your truck has a maf right now so you need the calibrator to calibrated it for your mods, go to Urdusa.com
    Induction is forced induction which refers to a supercharger it turbo. Turbo uses exhaust gases to create pressure and aupercharger used your belt to create boost.
  15. Jan 17, 2012 at 12:35 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
