exhaust leak coming from headers
Discussion in '1st Gen. Tacomas (1995-2004)' started by cheese7882, May 23, 2012.
  1. May 23, 2012 at 12:40 AM
    cheese7882
    cheese7882 [OP] Well-Known Member
    California
    2016 Tacoma TRD OR DCSB MT
    I just had my battery replaced today and the guy at the shop said it sounds like I have a leak near my headers. I checked it out myself and there is definetley a leak, whether its gaskets or an actual hole I do not know which. I was wondering how much OEM headers go for and if anyone knows a reputable website that sells them, or if I should just go to Napa Auto Parts and have them order me some headers.
  2. May 23, 2012 at 12:50 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Might not be your headers FYI, it could easily just be the gasket. Not sure about the 1st Gens but the 2nd just use a bimetal crush gasket. Replace the gasket and use a high temp silicone gasket type sealer and you should be more then fine. Unless its rusted pipes..
  3. May 23, 2012 at 12:55 AM
    cheese7882
    California
    I'll give that a shot. It passed smog back in January so im good for 2 years :) also, is there a difference between headers and the manifold? Ive never had to deal with exhaust before so I'm learning as I go.
  4. May 23, 2012 at 1:11 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Is your Taco a I4 or V6 engine?
    And when people say headers, they are referring to the pipes immediately off the engine.
    Manifold is different though, there is an intake manifold and an exhaust manifold. When people say exhaust manifold though they are refering to the exact same immediate piping off the engine. Same as the headers. Just different terminology.
    The intake manifold is on top of the engine and directs the incoming air flow to each of the cylinders.
  5. May 23, 2012 at 1:20 AM
    cheese7882
    California
    Its an I4, 2.4l 2RZ. I am familiar with the intake manifold, I just didnt know if headers and exhaust manifold were two different things or one in the same. By looking at pictures, I assume the headers are what plug directly into the engine block???
  6. May 23, 2012 at 1:20 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Let me dig up some pics, one min
  7. May 23, 2012 at 1:34 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Best I can find is this vid here. At 0:17 you see the thin plate horizontal off the left side of the engine? That is your exhaust heat shield, right below it are the 4 pipes that come out of each cyclinder before joining into 1 pipe. That is your exhaust header/exhaust manifold.
    http://www.youtube.com/watch?v=o8sc319umrQ&feature=related
  8. May 26, 2012 at 2:34 AM
    cheese7882
    California
    Yup, thats where the leak is coming from, that area. I'll buy a gasket first, hopefully that solves it. Otherwise, who makes a good header thats affordable? I prefer OEM, but if an upgrade doesnt cost that much more than I'll take the better.
  9. May 26, 2012 at 3:00 AM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If you have a leak, you will see black soot where the leak is coming from. Sometimes all a leak is a loose nut. Exhaust fasteners aren't tight due to the extreme temps they encounter and expansion and contraction of the metals can do this. See if you can snug up your exhaust manifold nuts and also the flange nuts that go down to your cat from the manifold. Not sure if you have to remove any heat shields to access your manifold or not, but be sure to hit those nuts with some WD-40 or equivilent when the engine is cold. It helps out alot. If you can't stop the leak by tightening the fasteners then most likely you'll just need new gaskets, but hey, if you're gonna take the manifold off, you might as well get headers and be more bad ass. Lots of different manufactures. Try googling headers for tacoma and go from there, also check out some of the 1st gen build pages to get some more info. Good luck
  10. May 26, 2012 at 3:17 AM
    cheese7882
    California
    I'll give that a shot. Thanks for the help.
