Exhaust leak why wont it stop!!!!!!!
Discussion in 'Toyota Trucks & SUVs' started by 1999tacotrd, Aug 31, 2009.
  1. Aug 31, 2009 at 10:21 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    After doing a motor swap i now have a exhaust leak that wont go away! i replaced the manifold gaskets and the exhust ring gaskets and it still leaks some where under the hood. I tighten the bolts down as tight as i can and it didnt leak before the motor swap so i dont know whats causeing it any ideas?
    its really loud as well as the cab gets fumes in it
  2. Sep 24, 2009 at 4:07 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    A leak that big & loud shouldn't be that hard to find, did you make sure all gasket surfaces are free of old gasket material? And when you tighten down ANY of the bolts holding your exhaust system together, tighten them a little at a time to ensure equal surface sealing ( especially those donut pieces of shit that I think all cars & trucks have) torque to specs. If none of this helps you need to check your exhaust all the way to the catalytic convertors, maybe damaged some of the exhaust tubing or connections during motor swap... good luck...:cool:
