Exhaust leak!
Discussion in '1st Gen. Tacomas (1995-2004)' started by SRQ TACO, Apr 19, 2011.
  1. Apr 19, 2011 at 10:54 PM
    SRQ TACO
    SRQ TACO [OP] Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Well it keeps leaking and its pissing me off! I put a new gasket in and it did no good and I also tried permetex and it failed aswell. How much do you think it would cost me to have a muffler shop just remove the bolt together part and weld in a straight pipe?
  2. Apr 20, 2011 at 1:55 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    I have so many exhaust leaks ear plugs don't even help haha. I thought about making a sleeve and welding over the area that is leaking. Instead of just completely straight piping it..
  3. Apr 20, 2011 at 1:57 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Qucik question i found a small hole right before my muffler and I mean as small at the head of a screw. That wont mess anything up will it?
  4. Apr 20, 2011 at 2:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    no it won't, but a muffler shop could fill the hole with weld for cheap. I would do it for free if you were local.
  5. Apr 21, 2011 at 5:16 PM
    mike sacc
    mike sacc Well-Known Member
    r.i.
    2001 tacoma reg cab, 2009 tacoma dble cab shb
    how about running asheet metal screw in the hole
  6. Apr 21, 2011 at 5:48 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    That would work if the hole is extremely small, like basically a pinhole because the rust will have thinned the metal around the hole.
    to be honest, some high temp RTV or JB weld might even work for a while.
  7. Apr 21, 2011 at 6:06 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    i say either weld over the hole, or straight pipe it, welding is fast and much cheaper
  8. Apr 22, 2011 at 8:38 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    Its not a hole its where it bolts together.
  9. Apr 22, 2011 at 5:40 PM
    mike sacc
    r.i.
    try some jb like steve o said. as far as welding rusty exhaust you can forget about that. i have an old plow truck for my yard , you can get some good muffler dope from your local napa. it works for me but its not permenant.
