Exhaust leak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mambojuice, Nov 18, 2018.
  1. Nov 18, 2018 at 11:03 AM
    Mambojuice
    Mambojuice [OP] New Member
    2001 Tacoma 2.7L v4 RWD
    Long time lurker, first time poster. This forum has been absolutely fantastic for helping me out with my 2001 Tacoma!
    I gave my engine the Seafoam treatment today (145k miles). Blew a lot of smoke out the tailpipe as expected, but also noticed some smoke coming from the engine bay. Took a closer look and it looks like some Seafoam had dripped out of the bottom of my engine right at the exhaust header. As smoke was billowing out the tailpipe it was also coming out from there as well.
    Here's a pic, the white streaks are where the Seafoam dripped and then dried up due to the heat of the pipe. Am I in trouble?
  2. Nov 18, 2018 at 11:07 AM
    02hilux
    Planet: EARTH
    There's a gasket that is sandwich between there. Just change it but be careful as the nuts may have been seized
  3. Nov 18, 2018 at 11:16 AM
    Mambojuice
  4. Nov 18, 2018 at 11:17 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Where was Seafoam dripping out of? You shouldn't be inducting so much that it's getting all the way to the exhaust manifold without being burned off. There is a gasket where the manifold mounts to the head, I believe the manifold flange on the 2.7 is prone to warping and causing an exhaust leak there. Not an expert on the 2.7 though @Speedytech7
    If any of the Seafoam is dripping on the manifold or downpipe, that's probably what's causing the white smoke you see.
  5. Nov 18, 2018 at 11:18 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Having an in-engine bay exhaust leak poses a health risk too, you could be getting CO fumes in the cab
  6. Nov 18, 2018 at 11:24 AM
    Mambojuice
    Yes, that's my biggest concern (otherwise I'd just ignore it as my truck has been pretty much set aside for Home Depot trips only).
    I suppose it's possible the Seafoam dripped out of the vacuum hose and ran down to the exhaust, my hoses are pretty cracked and shoddy (next item on my list). It's cold and wet here in the northeast so I didn't crawl underneath just yet, but it looks like I might have to.
  7. Nov 18, 2018 at 11:39 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah the whole design is bad for that flange, they all warp. Before I bought a header mine was warped and no matter what gasket you put it in wouldn't seal all the way and sounded like a motorcycle up hills.
    drr[QUOTED] and Wulf like this.
  8. Nov 18, 2018 at 11:44 AM
    02hilux
    Planet: EARTH
  9. Nov 18, 2018 at 12:33 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    yup. i used new donuts and half a tube of copper gasket maker. that did the trick before i went turbo.
  10. Nov 19, 2018 at 8:51 AM
    Mambojuice
    By any chance does anyone have a link or part number for the gasket?
  11. Nov 19, 2018 at 5:39 PM
    bigaltrif
    bigaltrif Well-Known Member
    Alex
    syracuse, ny
    Go to parts store and look st exhaust diagram.
  12. Nov 20, 2018 at 11:02 PM
    Yucel
    Yucel Well-Known Member
    San Francisco Bay Area
    2023 Tacoma TRD Sport
    O'reilly's has the flange. I just bought one and wish I knew the part number. once you split it open, take the old flange with you. Because they have few different ones, although they look similar...are not the same. I had to double back to the store and exchange it. After getting the right part, I sealed it with a high heat silicone, just a very small amount to get a good seal. I think the flange is a bit over 2".
