Exhaust Manifold Leak ? Or Maybe Not...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Feb 25, 2024.
  1. Feb 25, 2024 at 6:24 PM
    iJDub
    iJDub [OP] Well-Known Member
    OK, so I was 99.9999% sure I had an exhaust manifold leak. I have all the ticking that indicates there's a manifold leak etc... (loud metallic ticking, more pronounced in the cold) and under slight load at lower RPMs.
    Anyway...I ended up smoking it (using a smoke machine to test for leaks through the exhaust) and I couldn't find any exhaust leaks. Maybe the machine wasn't strong enough to get the smoke from the tail pipe to the manifold or maybe there's no leak?
    I'm going to get it on a lift next week and use some soapy water.
  2. Feb 25, 2024 at 6:33 PM
    TacoTuesday1
    SD CA
    visual inspection
    Soapy water when cold
    Another option is combusting smoke such as seafoam that smokes white out the tailpipe. If there’s a manifold leak the seafoam smoke show might be evident there too in theory.
  3. Feb 25, 2024 at 7:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Look for black soot around the manifold and exhaust connections
  4. Feb 28, 2024 at 9:02 PM
    iJDub
    Well, I was going to Seafoam my truck anyway - but I'll also try soapy water. Thanks.
