Exhaust Manifold leak vs P0402 code HELP
Discussion in 'Technical Chat' started by dustinclm, Jan 2, 2011.
  1. Jan 2, 2011 at 9:36 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    Can anyone tell me if a cracked exhaust manifold can trigger the P0402 code? the P0402 code is this.....
    P0402 - system fault exhaust gas recirculation - too much flow on EGR
    1) EGR valve stuck open
    2) failed EGR pressure sensor, or valve or pressure sensor
    .....or should i check the EGR valve and lines? if i need to check the valve or lines, what is the best do that? i know where they are located and ran seafoam through the motor. I am not positive the manifold is cracked but i can hear a "puffing" noise when driving and can not find a leak anywhere else so im assuming its a manifold leak but i do not smell any fumes or have other symptoms besides the "puffing". the manifold is covered by a heat shield and i cant remove the nuts of the shield because they are rusted on there pretty good. Or am i looking at two different problems?
    thanks
  2. Feb 9, 2011 at 8:42 PM
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    does your engine run rough at idle? if no then your egr is not stuck open... check the egr modulator
  3. Feb 10, 2011 at 10:10 AM
    dustinclm
    Thibodaux, La
    no, my truck runs really well, i would never know anything is wrong if it wasnt for the CEL. where is the modulator?
  4. Feb 10, 2011 at 8:09 PM
    The Munster
    Lance
    Moody AFB, GA
    its this little plastic circular thing right next to or close to the egr valve
