Exhaust manifold replace
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Criley530, Jul 26, 2017.
  1. Jul 26, 2017 at 10:23 AM
    Criley530
    Criley530 [OP] Active Member
    06 Tacoma
    Who knows?
    Hey guys.... Well about a year later and $900 ive found the problem with the p0430 code ive been having.bad cat bank 2.i did eveything up to this i.e. sensors gaskets seafoam . so i cannot find any how to on removing the manifold any links advise would be awesome
    2006 Tacoma 4x4. 4.0 3 inch lift front.
  2. Jul 26, 2017 at 10:30 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Take the exhaust pipe down after the cat then unbolt the header from the block. Spray some acetone/tranny fluid 50/50 mix on the exhaust bolts before you try to remove them. Do not use an impact. You will just shear the bolts clean off.
  3. Jul 26, 2017 at 10:33 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    do this a day or two prior, also do it with it hot but not burning the ATF off
    Bebop[QUOTED] likes this.
  4. Jul 26, 2017 at 11:34 AM
    Bebop
    Nick
    Good add on. Forgot about the let it soak part. That's what I get for multi tasking.
