Exhaust manifold still glowing.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cogneato, Dec 16, 2014.
  1. Dec 16, 2014 at 9:57 AM
    Cogneato
    Cogneato [OP] Active Member
    Justin
    Waco, Texas
    99 Prerunner SR5
    16" Duratracs, Westin Side Steps.
    Finally had a reputable mechanic run tests on my truck. Everything came back in spec and nothing seems out of the ordinary. He drove for awhile and told me he couldnt get the manifold to glow. I drove my truck a ways and back and sure as hell my exhaust manifold is still glowing red. I can only see it at night, but it's definitely glowing. What we have already checked or replaced:
    Upstream o2
    Replaced manifold
    Fixed exhaust leaks
    Checked cat (not clogged)
    Checked timing (perfect)
    Checks fuel trims (read at 9 on highway, 0-2 in city)
    Ran an entire systems check
    Temp in manifold at idle is 600-700 degrees
    Could the computer be bad? Should I have my fuel injectors changed? I'm just lost.
    I'm about to trade this thing in or sell it. I've already wasted enough money chasing this stupid issue.
  2. Dec 16, 2014 at 10:14 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Ill say this, but you prolly already know.......
    1.) Clogged Cat, but you said it is not
    2.) Bad MAF?
    3.) running way too rich (you said you had it checked)
    4.) cracked or busted exhaust valve. (you should hear it.)
    have you cleaned the throttle body?
  3. Dec 16, 2014 at 10:37 AM
    Cogneato
    Justin
    Waco, Texas
    99 Prerunner SR5
    I have not cleaned the throttle body. The MAF sensor is good. The truck seems to be running rich. I know I'm using a lot of fuel.
    The truck actually runs very well. Responds to gas well, no restrictions and I can drive it as fast as I want to with no problems. Just worried about that manifold getting so hot. I'm so surprised no one else has had this issue.
  4. Dec 16, 2014 at 10:39 AM
    Aw9d
    Aw9d That one guy
    You replaced the manifold, did you use a OEM part or something aftermarket?
  5. Dec 16, 2014 at 10:50 AM
    Cogneato
    Justin
    Waco, Texas
    99 Prerunner SR5
    The manifold I just put on is OEM. Got it from autozone to replace the cracked manifold that was on it
  6. Dec 16, 2014 at 11:00 AM
    05taco2.7
    05taco2.7 Well-Known Member
    JIMSTER
    omaha nebraska
    Soon to come
    Do you have a picture of this happening? Not doubting Id just like to see
    Could be fuel related, could also be possibly the manifold that was installed is flawed ie different alloy might respond to heat differently
  7. Dec 16, 2014 at 11:07 AM
    Cogneato
    Justin
    Waco, Texas
    99 Prerunner SR5
    No pictures. It would be hard to take a picture of this since I can only see it glowing at night and I doubt it would show up well on a picture.
    It has an even glow across the entire EM. The old manifold that was cracked is black in all 4 cylinders. I assume my truck is running rich...the question is WHY? And why is it so hard to pinpoint the issue....
    This truck also has 216k on it.
  8. Dec 16, 2014 at 11:23 AM
    05taco2.7
    JIMSTER
    omaha nebraska
    Soon to come
    Ok maybe try pming bamataco he might have some idea
  9. Dec 16, 2014 at 11:25 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    Are we talkin' "cherry" or just a little glow?
    exhaust gets hot, they will glow a little after driving around.
    black is carbon deposits, result of combustion, normal unless you have a 1/4"-1/2" of layer
    take the picture anyway and turn off your flash. without this info there truly seems to be nothing major :notsure:
  10. Dec 16, 2014 at 11:26 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    This...
  11. Dec 16, 2014 at 11:31 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    just replace the cat, its not like a HUGE dollar item, replace the cat and that will solve the problem.
    as I mentioned to you in the other thread, if its restricted it can "look" open (you can see through it) and not throw any codes (because it does still have exhaust flowing) but it will make your manifold overheat because exhaust isn't flowing freely and fast enough to carry the heat away from the engine.
    change the cat and problem is solved
  12. Dec 16, 2014 at 11:34 AM
    Cogneato
    Justin
    Waco, Texas
    99 Prerunner SR5
    Not sure how to describe "cherry" over any other glow. I just know its glowing and it's red and doesn't look normal at all.
    I'm wondering if I should straight pipe it and drive it around for a night and see if the manifold will still glow. Then I'll know it's the cat.
  13. Dec 16, 2014 at 11:37 AM
    Aw9d
    Aw9d That one guy
  14. Dec 16, 2014 at 11:38 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    what about driving style? If your driving it like Ricky bobby all the time its gonna get hot
    THatt likes this.
  15. Dec 16, 2014 at 11:45 AM
    Cogneato
    Justin
    Waco, Texas
    99 Prerunner SR5
    Yes it's only the manifold that is glowing. I called autozone just awhile ago and asked them if the manifold I bought was the OEM part for my truck and they said it was the "OE" part with gaskets and everything. It fit right on with no problems.
    I put a lot of highway miles on this truck but I don't drive it hard at all. I baby it. I'm a very defensive driver.
  16. Dec 16, 2014 at 11:53 AM
    Cogneato
    Justin
    Waco, Texas
    99 Prerunner SR5
    http://www.bohp.net/pict2/ment2g3729.jpg
    Hope y'all can see that picture. If this is what "cherry" red looks like, then no...my truck isn't doing that. It's only so red that you can see it at night. I would assume 700-900 degrees. How hot should a manifold get when normal?
  17. Dec 16, 2014 at 11:54 AM
    keakar
    karl
    louisiana
    maybe the manifold is just a cheap crap way too thin cast iron and it cant hold the heat so it gets too hot and glows.
    the best replacement manifold for our trucks is this stock header found on any 2.7L 3rz 2002 and newer trucks and is a perfect exact fit replacement for any 2.4L or 2.7L trucks from 1995-2004:
    http://s1076.photobucket.com/user/keakar63/media/3rzexhaustmanifold.jpg.html?sort=6&o=3
    they can be found in any salvage yard for around $50 or even bought brand new for around $150 and are heavy gage steel tubing that is better then those cheap aftermarket headers that are not dot legal.
    you should find you one of these and swap out that crappy cheap cast iron manifold you bought and you will know for sure the manifold isn't the issue because if your cat is restricted then it WILL ruin your engine to keep driving it that way. its like you trying to breathe through a straw, you can do it for a while but sooner or later you will pass out and die.
  18. Dec 16, 2014 at 11:56 AM
    Aw9d
    Aw9d That one guy
    OE is a different vendor cloning a stock part. No performance gains, just a cheaper made part. Typically this is ok for most parts.
    OEM is made by Toyota, or the auto manufacture, and its a lot better quality than what you'll get from vato-zone.
    I'll bet money you have 2 things going on.
    1. A clogged, or partial clogged cat
    2. A cheap exhaust manifold made of cheap materials.
    I'm still leaning towards the fact that its just a cheap manifold made from cheap materials and that's why it's getting red. Personally if it were me I'd take it back and get a real Toyota made manifold.
    THatt likes this.
  19. Dec 16, 2014 at 11:59 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I was under the impression that the chain parts houses don't carry anything OEM. Is that not the case? I always assumed all of their parts are aftermarket and OE replacements.
  20. Dec 16, 2014 at 12:01 PM
    Aw9d
    Aw9d That one guy
    You are correct, they do not carry OEM, only OE parts. I posted the part he installed from Autozone.com.
