Exhaust manifold?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CRiz, Oct 21, 2013.
  1. Oct 21, 2013 at 4:30 PM
    CRiz
    CRiz [OP] Well-Known Member
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
  2. Oct 21, 2013 at 5:08 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  3. Oct 21, 2013 at 5:12 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    i wish i could afford one of those :( but right now I just don't have the money for it
  4. Oct 21, 2013 at 6:03 PM
    ChrisTRD1
    ChrisTRD1 Member
    Oregon
    99 4x4 SR5 TRD
    Bilstein 5100s OME 551 Alcan 5-leaf
    Get a used manifold from a 2001-2004 Tacoma. They are tubular steel like a header so not prone to cracking, and they bolt right in with no modification. Can be had for ~$100 on www.car-part.com
  5. Oct 21, 2013 at 9:34 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Do I need to order new gaskets for those too?
  6. Oct 21, 2013 at 10:23 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    im unsure on how to order the mini header :(
  7. Oct 22, 2013 at 6:53 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yes. You can pick one up at the local dealer.
  8. Oct 22, 2013 at 7:46 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Well if I get one of those mini headers then i might as well save up the extra 100ish bucks and buy a Doug Thorley header and get some extra performance. I have a question tho will having on of those thorley headers hurt my truck? cause it already has 186,000 miles so i don't want to hurt the engine.
    Edit: I think this will be my best bet then! just gotta wait a couple extra weeks!
    http://urdusa.com/Exhaust-&-Headers...Tacoma,-1995-2000-2.4-&-2.7/product_info.html
  9. Oct 22, 2013 at 9:22 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
  10. Oct 22, 2013 at 11:43 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Does the guy still make them? The post is from 2009. If I'm paying 300 dollars plus 20 dollars shipping wouldn't it be better to just spend 50 dollars more for a Doug thorley header?
  11. Oct 22, 2013 at 11:58 AM
    PATACO13
    PATACO13 Well-Known Member
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    I had Doug Thorley header on my 2.7L for awhile. It might have been because of the rest of my aftermarket exhaust, but it was really noisy. And I didn't notice any significant performance improvements. I would just get a replacement manifold from rockauto or similar. And you shouldn't need to go to dealer for gasket, got mine from NAPA. Don't forget gasket for EGR if you have that.
    EDIT: Not saying DT header isn't a quality product, because the one I had was clearly well-made, nice looking and bolted right on perfectly. Just made a racket under the hood for some reason. I had 2.25 pipes, one cat and a Dynomax super-turbo muffler.
  12. Oct 22, 2013 at 12:00 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Nm I guess he does still sell them :) I guess I just need to decide which one I should get!
  13. Oct 22, 2013 at 1:09 PM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    Id prob just wait on gaskets then if u need em have wife gf or buddy pickem up local. Honestly I think youll gain pwr with whatever u get because itll be better then the cracked and leaking manifold I know my truck was much more quiet and more pep after header install
  14. Oct 22, 2013 at 8:45 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Thanks for the help man! I'm probably just gonna end up getting the standard manifold since I live in az I don't have much to worry about rust wise!
  15. Oct 22, 2013 at 8:48 PM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    I've also been noticing a problem recently where my engine seems to kind of howl whenever I'm accelerating and then it goes away when I stop accelerating. I don't know if it's normal and I'm just paranoid or if it could actually be something
  16. Oct 23, 2013 at 8:16 AM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    Criz mine was same way pic of crack in sig I think. Pull the tin heat shield n take a look.
  17. Oct 23, 2013 at 8:46 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Yup mine is cracked in the same general area only a little further down! And it's easily visible they the heat shield because it goes right past one of the circle cut outs in the heat shield!
  18. Oct 23, 2013 at 9:37 PM
    Azbaron
    Azbaron New Member
    Scott
    Tucson
    '99 Tacoma 4wd All stock
    Mine came from Sioux Falls and sounds like it's cracked. I got it tonight I live in tucson (had it delivered ). Guess I should be looking at replacing as well since Phoenix way dryer than SD. Did you go with a 2001 or a 1999?
  19. Oct 24, 2013 at 7:32 AM
    CRiz
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    I ended up just ordering the regular 1999 manifold. I don't think its gonna make much of a difference out here in AZ
