exhaust mileage increase
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PNWIW, May 11, 2008.
  1. May 11, 2008 at 5:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It would have to be. Im courious as to how they dynoed the truck to get the crank h.p. :confused:
  2. May 11, 2008 at 6:04 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    My son took it to get it read and I didn't see the process but was told it was a 22 HP gain over stock...so I assumed they meant the 190 (I'm a rook with the dyno thing. You definately know your stuff-is that all that I really am left with...around 170HP? How is that?
  3. May 11, 2008 at 6:08 PM
    PNWIW
    PNWIW [OP] Member
    western, WA
    07 TRD Off Road
    1" lift in rear, All pro coil overs in front.
    I sounds like the manufacturers of the exhaust systems may be wrong in there claim that there is an increase in mileage. Thanks
  4. May 11, 2008 at 6:24 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Yup we derailed another thread:eek: but yeah PNW I honestly don't think you'll save gas w/exhaust you're just freeing up more power from the motor...........back to the other thing-Chris, I can't believe that's all these trucks have at the wheels. This lil V6 pulls like a small V8 IMO. And it'll do 0-60 in about 8 second-and that's a 4100 lb truck. Where'd you come up with that difference? So the '86 Jimmy I owned was 5200 lbs, and had a 5.0 V8 rated at 152 HP.....so take away about 60 hp like you did-that truck only had around 90 HP?:eek:
  5. May 11, 2008 at 7:13 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^It's more than 190hp stock. Different truck, different results but generally I've seen them all over 200hp stock. These trucks are closer to 7 seconds 0-60, btw. I've verified that myself a couple of different ways (GPS and Gtech). That that I have much faith in magazine times but the majority of them have it around 7 seconds, too. That's based on my truck which weighs 3810lbs stock.
    http://www.autos.com/autos/truck/compact/2007/toyota/tacoma/prerunner_v6_style22
    Check this out: http://www.060calculator.com/ I am not in any way using that to prove my point but just found it interesting.
  6. May 11, 2008 at 7:17 PM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    Does anyone have genuine information with regard to this (not the my buddy did this and says, or I heard a guy say this) I want to get the TRD exhaust but we are savin money to buy a house and if I get a couple extra miles per gallon my wife might go for it!
  7. May 11, 2008 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The engine may produce the 190 h.p. at the crank ( most manufacturers before 2006 had a -2% and a +1% error allowed ). That rating was made on a bench with the base accessories attatched to the motor. The engine looses h.p. going thru the transmission, turning the drive shaft, going thru the rear diff, and then overcomming the rotational mass of the tires. The % of loss varies depending on drive configuration ( 4x4, auto, manual, etc.) and manufacturer. I have seen the Dodge 4.7 motor ( rated at 235 h.p. ) in a 4x4 with an auto crank out 186 h.p. to the tires. Thats a 49 h.p. loss thru the drive train. Corvettes on the other hand, are much more efficient. So, its not a set number that you subtract to get the rear wheel h.p., it a %. Also, dyno results can vary from one to the other, so when doing upgrades it is very important to use the same dyno and try to match the same atmospheric conditions. As far as the Toyota Tacomas go, all the 3.4's I have dynoed have put out between 149 and 154 h.p. to the wheels when stock. The 2.7's in a 4x4 manual has put down 104 stock. The 22 h.p. gain that they say you have gained could possibly be a "mathamatical" gain, where they take the existing CFM of the new exhaust and add it to the stock CFM the engine can push @ WOT, and "compute" the increased h.p. I have see people do this, and when we have tested this methode it has proven to be pretty optomistic. Also, Torque is what get a vehicle moveing. Your 86 jimmy may very well have been putting down 100 h.p. to the tires, but Im sure it was pushing 250 lbs. of torque to get the truck moveing.:)
  8. May 11, 2008 at 7:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    We were talking about the 3.4 v6. The new 4.0's are @ 200 or a little above when stco to the tires. :)
  9. May 11, 2008 at 7:20 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Hey Wilson-yeah maybe for yours because it's new (aren't you rated at around 235-240HP) I'm thinking maybe mine BEGAN with more HP than the standard rating? And Son and I did 3 runs with a good old'fashioned stpowatch and took an avg on the 0-60 and we did it after the new exhaust. I think that's an ok run for a small six!
  10. May 11, 2008 at 7:23 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Ah, I was thinking Ridge's last post there was in regard to the 4.0
    You were talking above about the new manufacturers ratings based on the new SAE standards. True, because the 4.0L went from 245 to 236 so if you have a 2005, you got 9 more hp. :D
  11. May 11, 2008 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have "genuine" information. I have spent quite a few years working on getting the most from engines. The best thing for getting more m.p.g. is your driveing style. The MOST m.p.g. increase I have seen from a Tacoma with a non stock intake, headers, and full exhaust ( that was propperly tuned, I might add :)) has been 2 m.p.g. If you want the exhaust, I say get it, bump your tire psi. up a few psi, and dont change your driveing style and you wil see a couple more mpg.
  12. May 11, 2008 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That could very well be a possibillity. :)
  13. May 11, 2008 at 7:26 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^I concur. I've been driving for over 20 years and have modded every vehicle I've owned and I've found that your right foot has the biggest impact on MPG.
  14. May 11, 2008 at 7:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The manufactures for 2007+ have to have all accessories running, full factory intake and exhaust to get the new rating. The H.p. is the same as it was in the 2006- years, just a different methode of testing. Kinda shows the loss right there of a few accesories and the like. If the manufacture meets certain criteria, they may also get the rating "certified" wich means that it puts out NO less than what it is rated at. So far, as far as I know, only GM and Toyota have given certified ratings for some of their vehicles. For GM its the Corvette, and the 5.3 and 6.0 truck motors. Toyota has certified the 4.0 in the Tacoma and the FJ last I heard. :)
  15. May 11, 2008 at 7:34 PM
    #35
    Ridgerunner
    Frank
    Rocklin, Ca.
    Well anyway I'm talking out my ass on this stuff because I didn't go there too and educate myself. But the power increase is noticeable enough that I'm really content with it and am glad I got that done. I love the twin pipes look on these trucks and I've got my own signature sameside style to go with da growl:D you think I picked up more torque?
  16. May 11, 2008 at 7:43 PM
    #36
    ChrisDeSoup
    Up in ya
    Thanks dude, I try to drive 65-75 (instead of 75-85) and avoid the city.... I will take your advise and put my tire pressure a few PSi over.... My wife may or may not let me get the exhaust (I seem to have had my balls removed:D)!!
  17. May 11, 2008 at 7:47 PM
    #37
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Just getting a higher flowing muffler should help a little. It's what I did and I consistently get 18mpg city, even with larger than OEM tires.
  18. May 11, 2008 at 7:52 PM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Without seeing your setup its hard to make a guess. You went with a larger muffler ( a good thing ) and went with larger 3" pipes ( not such a good thing on these motors ). I think you may have gained a good amount of torque on the mid to top end, but I would think ( one again without seeing your setup ) you may have lost some on the bottom. I have ran a couple of 3.4's on a dyno with a similar exhaust as you have, i.e; daul pipes and a bigger muffler, and that has been the norm. It still gives a performance increase as the truck is now pulling a little harder in the mid to top end, and if you have good gearing, you may not feel any loss on the bottom.
  19. May 11, 2008 at 7:53 PM
    #39
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL. I know the feeling. My wife keeps mine in her purse. I take them out when she's not looking. :D
  20. May 11, 2008 at 7:55 PM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    True. Just stay away from the "baffled" mufflers( Flowmaster ), as they actually give a loss on these trucks. They sound cool, though. :)
