Exhaust Note Idea
Discussion in 'Performance and Tuning' started by Brunes, Oct 22, 2008.
  1. Oct 22, 2008 at 10:00 AM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    So- I've decided- I'll be building a true dual exhaust for my Tacoma. Thanks to KaliTaco-I've worked out some pipe routing issues and I've been inspired to black out the ends.
    This is a very obtuse question-BUT- I've been shopping Magnaflow mufflers. I've settled on the round type to be able to fit both in the standard muffler location.
    However to get the performance and a great sound- I'm not sure about the muffler lengths or styles. I wanted to see if anyone had tried the round mufflers (Either the Satin Stainless or Race Series).
    I'm thinking that a longer, larger diameter muffler will give deeper sound- I'm thinking 2.5 inlet 2.5 outlet. Not sure between a 5,6,or 7 inch diameter muffler.
    Okay- So to finish rambling- Anyone have a Race Series or Round Stainless Magnaflow Muffler?? Pros/Cons/Suggestions...Let me know what you think.
  2. Oct 23, 2008 at 2:34 PM
    gtz85350
    gtz85350 Well-Known Member
    Yuma Arizona
    08 SR5 sport
    Any pics of the black tips?? Sounds sick!
  3. Oct 23, 2008 at 2:44 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    FWIW, Chris4x4 said the Dynomax mufflers give the most performance and a nice sound:)
  4. Oct 23, 2008 at 2:57 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    check out will's dynomax super turbo in his build, tacomaman06's build, it sounds sweet!
  5. Oct 23, 2008 at 2:58 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i also run a dynomax muffler way better then the borla i had on it, went with the super turbo better sound better performance over magnaflow and borla imo
  6. Oct 23, 2008 at 4:11 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    That's right! I forgot about Will's-it does have that sort of "half GT half bigrig" sound which is perfect for a truck:)
    Wow vt-that's interesting cuz I was under the impression that Borla was the bomb-guess not!:)
  7. Oct 23, 2008 at 4:14 PM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    So here is the question for the physics majors in the crowd-
    For a deeper sound- do I want a longer or shorter muffler? Do I want smaller diameter or larger??
  8. Oct 23, 2008 at 4:18 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    i went with a 20" muffler well 25" overall and went with 2.5 same as stock pipe i think it sounds awesome
  9. Oct 23, 2008 at 4:38 PM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    I looked at the Dynomax site- The only problem I would have is that it won't be a true dual system if I was a Dynomax pipe....and that was kinda my goal.
    Maybe that's where my flaw is- Is a true dual set up not worth it??
  10. Oct 23, 2008 at 4:56 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    thats where you need to really ask yourself do you really wanna spend all the extra money and time, i spent $55 for the muffler and i cut mine off and welded it myself just cause i knew i wasnt gonna be taking it off, ive got the 2.7 and i can really notice the difference power and sound
  11. Oct 23, 2008 at 5:05 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    You know there's a certain point where too much freedom in the exhaust becomes the enemy of torque and HP on these V6s. The one inlet-2 outlet system offers a decent amount of increase in power without going overboard. There's a whole phenomenon with exhaust "scavenging" and exhaust "pulsing" and "valve overlap" in play here that I will have Chris4x4 come here and explain so you make an informed decision:)
  12. Oct 23, 2008 at 6:24 PM
    KaliTaco
    KaliTaco Well-Known Member
    i know it will turn out great. my tips was 8 inch but 7 inch would give you more room to work with. if you can..dont get any chrome or polish, stainless tips. because you need to sand them down. but if you have to then get stainless and rough it up with 800 grit sandpaper before painting. cant wait to see pics.
  13. Oct 23, 2008 at 7:20 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    bumped for Chris4x4 to answer
  14. Oct 23, 2008 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A "true dual" system will kill your low and mid range power. You "May" see a top end gain. Your exhaust system is not just an outlet for spent gasses, but a tuned system. As the piston moves up to evacuate the chamber of exhaust, the valve opens and the exhaust leaves the cylynder in a "pulse". This puls, since it has mass, is pulling behind it a low pressure zone. This pulse moves down the exhaust as another exhaust valve is opening. As the other valve is opening, the exhaust gasses in its cylynder are now "Sucked" out of the chamber by the low pressure zone behind the first pulse. This cycle repeats. To add, when the exhaust is pulled from the cylynder, a "vaccume" is now formed in it, alowing the Air/fuel charge to be "pulled" into the cylynder. and on and on. With VVT this is kept pretty constant thru the rpm range. ANy changes in the exhaust system have an affect. Some better, many worse. Adding a true dual system to the truck is going to null and void almost all scavenging of the engine, thus you will loose power.
  15. Oct 23, 2008 at 8:17 PM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    I understood every word of that- but never looked that far into the engine to find out about how it would react to a true dual. ::feels a bit ashamed::
    I guess I'll be looking a different route now...Thanks chris.
  16. Oct 23, 2008 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help! :proposetoast:
  17. Mar 2, 2009 at 6:31 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    This is exactly true. But one thing to keep in mind is the length of that pulse. With the DT long tube headers the collector will act as the rebound wall. Anything passed the collector will only have an effect on the back pressure, and in theory the speed of that pulse rebound.
    This is why you lose lowend with open exhausts. The pulse/rebound gets out of sync at low rpms (lack of back pressure), but as the RPMs pick up that timing is optimized. Now with forced induction, because there is much more gas that needs to be expelled, you can get away with the open exhaust at low rpms without losing as much lowend.
  18. Mar 2, 2009 at 6:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I didnt want to go into the length of the pulse and so on....I wanted to just keep it simple. Did a write up a while back on this:
    http://www.tacomaworld.com/forum/technical-chat/19967-how-air-goes-thru-your-engine-basic.html
  19. Mar 2, 2009 at 7:40 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
