Exhaust Pipe Trim
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wadar, Sep 1, 2015.
  1. Sep 1, 2015 at 6:54 AM
    Wadar
    Wadar [OP] Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    I just did my suspension lift yesterday, and I have some interaction between the leaf springs and the exhaust pipe. I used the OME exhaust bracket and that didn't help when the Toytec shackles were at the 2" setting. Currently I have the shackles at the 1.5" setting, and still getting some interaction between the tail pipe and the leaf. I've looked around on line and seen many people just cut their exhaust after the down turn. However before I do something that I regret, (and can't undo) are there any problems with chopping the pipe at the first downturn behind the rear axel? Anyone have a better solution?
  2. Sep 1, 2015 at 12:37 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    the main reason for the exhaust to, well, exhaust the fumes away from the vehicle. exiting on the side allows the gases to float off into the atmosphere and not gather under the truck. If you are moving this is a non-issue but if you do a lot of stop-and-go it could add extra heat underneath.
    all-in-all it's probably not going to have any ill affect.
  3. Sep 2, 2015 at 12:34 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    i just welded about 2" to the hanger that's attached to the tailpipe.
  4. Sep 2, 2015 at 6:37 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I just installed an aux fuel tank in the spare tire location. The exhaust was in the way so I chopped it off just after the muffler and added a down turn.
  5. Sep 2, 2015 at 6:40 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Biggest problem with cutting it off at the axle is you will blow dust up everywhere with it pointing at the ground.
  6. Sep 2, 2015 at 6:41 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    Chopping it right past the axel is common. No worries.
  7. Sep 2, 2015 at 6:49 PM
    Wadar
    Wade
    A few.
    Thanks for the input... I did it. Grabbed the ol sawzall, and cut er' short. After getting that pesky tail pipe out of the way I was able to get the full length out of the shackles. I'm pretty happy with the results, got my lift in, and my big tires on. The truck is starting to come together! I'll get some pics of the final product soon!
    ElScorcho likes this.
  8. Sep 2, 2015 at 7:02 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I bet you could bring it to the muffler shop and have a new pipe that clears put on it for less then $50.
    in slow traffic and heavy fog or rain you could be breathing carbon monoxide coming from under the truck if it isn't directed out from under the truck, just sayin. in bumper to bumper traffic you would get nautious from it with the windows down
  9. Sep 2, 2015 at 7:45 PM
    Wadar
    Wade
    A few.
    That was a concern, (the CO poisoning) my best solution for that is to stay in the mountains where we don't have bumper to bumper traffic. That said I'll need to replace the exhaust sooner than later, The muffler is kinda haggard. When that time comes I'll look into some custom rerouting.
  10. Sep 3, 2015 at 7:24 AM
    otis24
    Mark
    California
    That's a good point, here are my thoughts. The down turned exaust tip is about 20 inches off the ground. Further more while traveling dirt roads for any extended period of time dust is going to get everywhere. It's best to accept things will be dusty and continue having fun. I've yet to hear about or see this being an issue.
    Regarding CO collecting under the truck and working it's way into the cab. Have you guys seen the amount of space under the truck? The exhaust has plenty of room to dissipate. Also if you're in bumper to bumper traffic There's bound to be an exhaust pipe closer to your lunges than the one on your truck....you're kinda surrounded by them.
    I will say that if you drive with the bed off, chopped exhaust and rear window open you will get exhaust in the cab.
    CrawfishTaco and ThunderOne like this.
  11. Sep 3, 2015 at 8:19 PM
    Indy
    Indy Master of all I survey.
    Its not the overall gathering that's generally the issue, its the ability to then leak into and concentrate in the cab. Same reason people die every year.
  12. Sep 3, 2015 at 8:24 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Is there any evidence to support this fearmongering? Thousands of people have made the mod, including myself, and there have been exactly zero reported injuries or death that I know of. If you have contrary facts please share.
    4T3Underhill, CrawfishTaco and otis24 like this.
