Exhaust question: reposting in a more simplified/direct way
Discussion in 'Performance and Tuning' started by KMFDM_V, Jun 27, 2017.
  1. Jun 27, 2017 at 7:03 PM
    KMFDM_V
    KMFDM_V [OP] Well-Known Member
    Ken
    Sacramento, CA
    09 Timberland Mica 2.7L 5MT 4x2 Access
    I may have tweaked a few things...
    I had a 14" Magnaflow installed. They were afraid I wouldn't hear the 18"...
    So to quiet it down they installed a 12" glasspack, with the scoops set to be more restrictive/most quiet. I like how much it quieted down, and it usually stays low because I try to shift by 2.5k.
    I'm not concerned with power numbers, I'm just the kind of person that feels the more subtle changes in things. My feeling is that the glasspack makes the throttle feel more 'stuffy', less responsive, compared to how it was feeling after swapping out the stock exhaust.
    Does that make sense or is this just in my head? I'm considering getting a longer, straight-through glasspack and an 18" muffler to have less sound but be more free flowing. Or will that just be a waste of money for no perceivable difference in throttle response?
  2. Jun 28, 2017 at 10:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    18" straight through, is my opinion. Mainly because I a running one. Lol.
  3. Jun 28, 2017 at 10:47 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Well realistically... The more open you make the exhaust on that 2.7 of yours the more low end torque you stand to lose which will lead to increases in the "stuffiness" feeling. It actually probably helped you, but the sound profile changed to where you think that there is something wrong. I run a muffler as well as an 12" glasspack and still feel like my exhaust is too open. I'm not WOT enough to warrant the miniscule power gains up top and would like my power band to be pushed a little further down. I might swap to an 18" here soon enough myself.
    TL;DR - Its probably in your head
  4. Jun 28, 2017 at 12:27 PM
    KMFDM_V
    Ken
    Sacramento, CA
    I hadn't thought of it that way, that's an interesting thought. If it hadn't felt how open it was before the glasspack I might be inclined to agree.
    I spoke to the head guy at the shop this morning and he sounded surprised that adding a glasspack was suggested to quiet it down when the first muffler was too loud. He named another brand that is supposed to be the best combination of free flowing and lowest sound. I'm going in later today so we'll see what they suggest next.
  5. Jun 28, 2017 at 6:05 PM
    KMFDM_V
    Ken
    Sacramento, CA
    I think you may have had it right after all. The shop replaced the Magnaflow with a Dynomax Super Turbo and left the glasspack in. The sound is now a quieter, lower tone, right about where I want it. And the truck feels much better now overall. Taking off from a stop feels much smoother and I don't have to give it extra gas to keep it from stalling. Would that have been caused by the initial lack of back pressure due to too much free flow?
  6. Jun 28, 2017 at 6:45 PM
    memario1214
    Colton
    Missoula, MT
    I don't really want to get into the weeds on a discussion of backpressure vs exhaust scavenging, but the long and short of it is yes. Theoretically with the arrangement that you were running prior you would have been losing power down low (and conversely probably gaining a tiny bit up high) due to a decrease in backpressure. A few ponies lost in real life on a vehicle like ours makes a big difference, especially since we make the majority of our power in the upper RPM range.
  7. Jun 28, 2017 at 6:55 PM
    KMFDM_V
    Ken
    Sacramento, CA
    No worries, I'll dive into that on my own time. Identifying the problem correctly will set me on the right path. Thanks for sharing your knowledge!
