Exhaust question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by F75gunslinger, Sep 2, 2022.
  1. Sep 2, 2022 at 3:07 PM
    F75gunslinger
    F75gunslinger [OP] Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    I'm in the market for a new exhaust . The one I currently have is fine except the top.of the muffler rotted out . Looking at a few older posts I've seen a couple people say that the tubes themselves were actually stainless , while the mufflers weren't . If that's the case , I'd rather just do a new muffler instead of buying the entire TRD exhaust . Add to that , the TRD exhaust for the 2nd Gen seems to be back ordered . Not surprising really as they're as old as they are . Just looking for any suggestions or info that you guys can share !
  2. Sep 2, 2022 at 4:48 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  3. Sep 3, 2022 at 6:57 PM
    Soulsurvives
    Soulsurvives Well-Known Member
    Bill
    2009 Tacoma
    I had a dynomax on my 09 and did not like it. Too much drone at low rpm for me.
  4. Sep 4, 2022 at 10:08 AM
    F75gunslinger
    Christian
    Rochester,NY
  5. Sep 4, 2022 at 3:49 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Cheap is the Walker SS Quiet Flow sold everywhere not highest quality but lifetime warranty.
    Drone not too bad and idle is quiet and at full throttle it gets loud, as you want.
    Can get the front muffler up to cat straight pipe also and the tailpipe if wanted also but the tailpipe is the old bend type with lots of bend ribs.
  6. Sep 7, 2022 at 10:34 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I love my Black widow muffler. 1million mile warranty.
    12TRDTacoma and nudavinci64 like this.
  7. Sep 7, 2022 at 10:49 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Subbing as I'm probably going to need a catback in the near future, my guess at least as I also have a 2010 on the original pipes and muffler. Single cab 4 cylinder..don't need loud though a little more free flowing than the stocker ain't bad
  8. Sep 7, 2022 at 11:08 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Go TRD, it’s a great system:thumbsup:
    For some reason the link fails to load,
    (PT910-89060) ext cab/dcsb
    they’re available at BAMwholesale
  9. Sep 8, 2022 at 12:46 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I have a cheap MBRP exhaust on mine and I really like it. Sounds great considering it's on the 1GR which pretty much sounds like ass no matter what.
    tx novice likes this.
  10. Sep 8, 2022 at 1:28 AM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    Hahaha...I compare the sound to a cement truck.
  11. Sep 8, 2022 at 4:05 AM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    I had read that concern in a few reviews before I bought mine but have found it to be pretty quiet unless I'm really pushing the gas. Of course, I'm coming from a TRD system that had completely rusted through right past the muffler, so my perspective might be a little skewed... :D
  12. Sep 9, 2022 at 7:47 AM
    10thMTNgrunt
    2013 TRD Sport
    Your stainless TRD system rusted through? Was it an OEM exhaust on a TRD Tacoma or a TRD exhaust system (not the same thing)?
  13. Sep 9, 2022 at 4:48 PM
    Doc Samson
    Almost NoVA
    None... yet.
    Hmmm... it was the OEM exhaust on my TRD Sport. Definitely NOT stainless because the whole thing is/was a solid crusty brown...
  14. Sep 9, 2022 at 5:32 PM
    10thMTNgrunt
    2013 TRD Sport
    Damn shame, hopefully your frame is still in decent shape.
  15. Sep 9, 2022 at 5:50 PM
    RHHousehold
    RHHousehold Well-Known Member
    CA
    2008 Access Cab TRD Offroad 4x4 V6
  16. Sep 10, 2022 at 6:22 AM
    Doc Samson
    Almost NoVA
    None... yet.
    Yes, bought the truck because the frame and leaf springs had just been replaced. It was a weird combination of almost new/very rusty, with the exhaust being the rustiest. Didn't really give it much thought as it passed inspection in Oct. but glad I replaced it before inspection this year.
    10thMTNgrunt[QUOTED] likes this.
  17. Sep 10, 2022 at 11:00 AM
    ABA180
    East Bridgewater MA
    Better to need an exhaust versus frame, plus at that age the exhaust is an expectation.
  18. Sep 10, 2022 at 11:31 AM
    10thMTNgrunt
    2013 TRD Sport
    Hell yeah on the new frame and leafs!
  19. Sep 10, 2022 at 11:57 AM
    Doc Samson
    Almost NoVA
    None... yet.
    Indeed! Did a lot of "replacement" work this summer but all of it was to be expected and the truck is in great condition!
    That is what sold me on it! I had probably looked at 10-15 possible "buys" prior and every single one had some significant issue. I still had a few things that needed doing on this one but, for a 200+k truck, it's been good to me!
  20. Sep 10, 2022 at 11:59 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Black Widow for the win. :thumbsup:
    tattooedsnake[QUOTED] likes this.
