exhaust rattle...2.7L
Discussion in '1st Gen. Tacomas (1995-2004)' started by brelandt, Aug 27, 2010.
  1. Aug 27, 2010 at 7:46 PM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I have a very loud exhaust rattle coming from under the cab after I put my automatic tranny in gear. Doesn't matter if it's "drive" or "reverse". Seems to happen mostly when the engine is cold but will still do it when warm as well just not as often. Also goes away when I accelerate.
    Is there a "common" part that is causing this? Plan on getting underneath to check it out in the morning but just wanted to see if there was something I ought to be looking at first before I waste my time looking in the wrong areas!
  2. Aug 27, 2010 at 8:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Check the heat shield above your cats. My v6 has 2 catalytic converters. Not sure what the 2.7Ls have.
  3. Aug 27, 2010 at 8:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    either the heat shield or the cat is actually bad, but I would think the CEL would be on it the cat was bad.
  4. Aug 27, 2010 at 9:13 PM
    brelandt
    Terry
    Dublin, CA
    well i hope it's not the cat. I only have 68K on it. LOL I am throwing a code for the O2 bank 1 sensor, but it's been on for 3 years now!
  5. Aug 27, 2010 at 9:33 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i bought my 2010 in march, i noticed the same rattle the 1st time i started it after bringing it back home, goes away after it it warms up..... should i worry about that? maybe i should look at the heat shield when i get back home.
  6. Aug 28, 2010 at 9:32 AM
    brelandt
    Terry
    Dublin, CA
    well, after thinking back to when I bought mine in jan 2004 I remmeber it doing the samething then and the dealer fixed it. Just not sure what they fixed or even how they fixed it. My only concern then was that the noise was gone.
    I guess this is another one of those, "Tacoma" issues that most of us just live with like the rattle under the dash on the passenger side! and the coin tray always opening when you hit a rough patch of road.....LOL
  7. Aug 29, 2010 at 2:57 PM
    brelandt
    Terry
    Dublin, CA
    ok went under the truck and found the issue. Seems that there is a bracket on the bell housing that extends to the pipe and there is a round clamp with a single bolt holding the 2 together. my clamp loosened up enough that it slipped off of the bracket and was resting on the O2 sensor.
    Fix was easy. Just loosen the bolt a few turns place it back on the bracket and then stick a 12mm socket and extension between the top of the frame and the wheelwell where the small rubber splash shield is and tighten the hell out of it.
  8. Aug 29, 2010 at 3:01 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I used to have a rattle, it was my exhaust banging on my shackle/hangar
