exhaust re-routing pictures?
Discussion in 'Performance and Tuning' started by eric3187, Aug 31, 2012.
  1. Oct 5, 2012 at 9:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You would still have the two necessary cats that are read by the O2 sensors, if you only upgraded to the URD Y, and not headers as well.
    If you aren't from Cali, it won't matter. Plus, in your state, you will pass emissions with the front two cats only.
  2. Oct 5, 2012 at 11:19 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I guess these y pipes serve the purpose for high clearance but not the purpose of performance. You get what you pay for.
  3. Oct 5, 2012 at 11:38 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    exactly...these all show only clearance gains...i.e. wanting to put a ATO or similar tranny skid on
  4. Oct 5, 2012 at 12:01 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Damnit, you're completely correct. I ran it by some exhaust pros I'm now working with and they said it won't be terrible, but the way it is isn't ideal. Grrrr.... Thanks for catching that!
  5. Oct 5, 2012 at 12:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My pleasure sir. :thumbsup: Glad I could help.
  6. Sep 19, 2013 at 12:05 PM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    This is pretty much exactly what I want to do. Maybe a tad more room behind the transfer case. Did you have stainless steel tubing used? Also, any thoughts on ceramic coating the newly created 'y' pipe?
    I plan on getting a full set of Relentless skids. It looks like all of these crossover re-routes would be outside (to the rear) of the back of the transfer case skid. Bummer but I guess it's not really an issue since it's up so high. Would have to cut a second exhaust clearance hole on the drivers side of the skid for the pipe to come out then turn it immediately to the passenger side. I guess I'll find out for sure once I get my skids and take a look. :)
  7. Sep 19, 2013 at 3:25 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Finally got mine fixed from the earlier "T," thanks to Torspd!
  8. Sep 19, 2013 at 3:39 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    60$ at my local shop. enough clearance for my flat transfer case skid.
    Pirhett likes this.
  9. Sep 19, 2013 at 4:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Now that looks much better mate. :thumbsup:
  10. Sep 19, 2013 at 6:57 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Oh man... that's a great improvement. :thumbsup:
    The T was truly painful to look at. It was like a plumber did it.
    I really like how nothing needs to pass under the trans. You know, that junction forms the third Y of a tri Y exhaust design. Have you noticed any more bottom end pull with that setup? Moving that third Y farther back increases the effective length of the "header" tuning. And the longer the header, the more bottom end torque you get. :)
  11. Dec 15, 2013 at 5:26 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Bumping this thread back to life.
    Looking for more example photos!
    I need to reroute my exhaust to clear a Pelfreybilt t-case skid.
    Several good examples here. I'm worried that the crossover close behind the t-case might cook the grease in the U-joint. Anybody have issues with this?
  12. Dec 15, 2013 at 5:46 PM
    SconnieHailer
    Marc
    see my version of the ypipe reroute... Good option. Same style that Tyler of "pelfreybuilt" did. Minimal pipe cut and change. I have all three pelfrey skids.
  13. Dec 15, 2013 at 5:51 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I put on the full set of Relentless Offroad skids (3 pieces) using the bone stock V6 exhaust. The skid has about a 1" bump out" section to clear that stupid stock crossover. So far so good, but I know somday I am going to be hung up on a rock and that "bump out" is going to be the reason.
    I like the URD "Y pipe", but a bit concerned if I have to eliminate those cats that I had to pay for. will that cause my truck to throw a Check Engine Light? I drive a GTI that is big turbo and half legal making it a dance to get through emissions testing, not willing to go this way on my Tacoma.
  14. Dec 15, 2013 at 5:59 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    URD FTW!!!:cool:
    Pirhett likes this.
  15. Dec 15, 2013 at 6:56 PM
    #35
    qnyla
    NM
    Thanks Sconnie, that is what I am looking for.
    My thoughts exactly.
    Too custom for me. Looks cool.
    SconnieHailer's pics reposted from his thread. Looks good. These are the same skids I need to clear.
  16. Dec 16, 2013 at 4:34 PM
    #36
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    Too custom? No such thing!:p it's bolt on!
  17. Dec 16, 2013 at 4:40 PM
    #37
    Lucario Runner
    Robert
    06 Toyota 4Runner
    urd y will not cause a cel.
  18. Dec 16, 2013 at 5:38 PM
    #38
    SconnieHailer
    Marc
    I've considered the URD but worried about opening up the exhaust too much on the NA motor... I don't want to kill anymore of my low end torque!
  19. Dec 16, 2013 at 5:40 PM
    #39
    Lucario Runner
    Robert
    06 Toyota 4Runner
  20. Dec 16, 2013 at 5:44 PM
    #40
    SconnieHailer
    Marc
    say wha! I noticed my torque curve move up in the rev range when I moved to a magnaflow flowthru muffler. That's my reasoning for the opening up of the Ypipe region moving that torque up even higher in the rev range, something not super useful to me. Why the sigh?
