Exhaust Shield
Discussion in '4 Cylinder' started by beatlebrown, Feb 25, 2013.
  1. Feb 25, 2013 at 3:44 PM
    beatlebrown
    beatlebrown [OP] New Member
    Nova Scotia
    2006 Toyota Tacoma
    Hey guys,
    I'm sure this has been discussed before, but I have a noisy heat shield over top of the exhaust.
    It's attached in 3 places and of course, the one which appears loose (in the front) is the hardest to access (ratchet won't fit and the nut appears to be countersunk in the aluminum so even a wrench is painful).
    I've tried bending it, also stuck a few tap con screws in it but the noise keeps coming back so...I'm thinking of removing it although it's obviously there for a purpose.
    Has anyone removed theirs and if so, have you had issues or heard of any?
    Feel free to weigh in.
    Tks...Tim
  2. Apr 30, 2013 at 12:18 PM
    Wrymouth
    Wrymouth New Member
    Nova Scotia
    05 SR5 V6
    Fog lights
    I cut the back half off mine (it was hanging loose and rattling) about 6 months ago and haven't had any problems.
  3. Apr 30, 2013 at 12:53 PM
    Speck
    Speck Well-Known Member
    Tejas
    07 2.7 4x4
    I have used hose clamps to secure them when the welds pop loose (on a previous car). It may not cause any problems to remove them, but when dealing with something that protects your car from excessive heat, why risk it?
  4. Apr 30, 2013 at 1:02 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I used bailing wire to "clamp" it to the piping so it would stop rattling.
  5. May 1, 2013 at 8:59 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I squeeze high temp silicone underneath hot rattles. :)
  6. May 2, 2013 at 4:59 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    I have a shield for a manifold style 4cyl yousr if you want it free pay shipping. I went to a 01+ header and not running heat shield
