exhaust smell... I think
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Guspuppy, Feb 11, 2015.
  1. Feb 11, 2015 at 12:12 PM
    Guspuppy
    Guspuppy [OP] Well-Known Member
    Corinne
    western PA
    2010 RC base 4x4 stick
    Every time I shut off and get out of my truck I can smell what I believe is exhaust coming from underneath. Not up by the engine (so probably not leaking manifold) but from about the middle of the truck. I haven't crawled under to check for holes because it's winter in PA and the underside is nasty. I'm wondering if this is something that a) I should worry about, and b) is it covered under the TCUV warranty? My truck is a 2010 so it is well out of manufacturer's warranty, but it only has currently 27k miles on it, so the exhaust warranty is still in effect until October 2016 I think? The 7-year, 100,00 mile one? Or is that only the limited drive train warranty? I know certain exhaust parts are not covered, like the muffler, but are the cats covered? Thanks!
  2. Feb 11, 2015 at 3:56 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    First, get out of the truck after you start it and walk around the truck to see if you can Hear a leak.
    Are you sure it's not just smoke from a greasy / oily spot(s) on the Engine/ Exhaust?? (Does it do it when you shut if off when the engine is just started - ie engine still cold).
    Check with the Toyota site - I believe the engine to Cats and covered for 75k? miles? Check it out ..
  3. Feb 12, 2015 at 8:02 PM
    Guspuppy
    Corinne
    western PA
    I did that this morning and did not smell anything right after start up. I have no idea what an exhaust leak would sound like. I never smelled anything all day today though. Usually I notice it in my garage when I park for the night though. So maybe it is something burning off the exhaust.
  4. Feb 12, 2015 at 9:43 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    An easy way to check for an exhaust leak is to have the engine running then very briefly plug the exhaust with a rag or something similar while listening for the exhaust to be escaping from the suspected leak.
    If you have a lot of road salt/grime on the exhaust system, this could be creating a burning smell too.
  5. Feb 13, 2015 at 7:03 AM
    Guspuppy
    Corinne
    western PA
    Ah! I wondered about that. It's PA, we've had a TON of salt on the roads the last few weeks. I just did a really good rinse of the truck and underside the other day but not a carwash with soap. That might be it.
