Exhaust Smell very bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hans512, Oct 24, 2017.
  1. Oct 24, 2017 at 5:12 PM
    Hans512
    Hans512 [OP] Member
    Hans
    Tacoma 2015 1GR-FE
    Haltech Elite 2500 Accel coils OBX headers
    Hi folks,
    I own a 2015 V6 taco, very nice truck.
    I have a problem with the exhaust smell... smells like uncombustioned fuel getting out from the exhaust.
    Truck idles smoothly, hang an AEM wideband sensor, 14.7 afr with very little oscillation.
    Flow tested the injectors in the bench, they are pretty well in terms of flow and leaks.
    Spark plugs are good all the six, tried also each coil, and borrow my friend's coils, no difference at all.
    Oil consumption isnt noticeable.
    Engine has some mods, long tube headers (no cats).
    I wouldnt expect that gas exhaust smells like roses, but mainly, every gasoline car i had, didnt have this problem.
    Any ideas or any other test to perform?
    Pd: last week took out the plastic intake manifold, found the aluminium manifold with some residues of fuel (pinkish color) i think is wierd that fuel is there, considering that inyectors are after this part of the manifold.
    Thanks in advance
  2. Oct 24, 2017 at 5:51 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  3. Oct 24, 2017 at 5:58 PM
    inwood customs
    Dave
    Using any coolant?
  4. Oct 24, 2017 at 6:06 PM
    Hans512
    Hans512 [OP] Member
    Hans
    Tacoma 2015 1GR-FE
    Hi bro, using the factory coolant. Car has 20k miles, no signs of coolant consumption
  5. Oct 24, 2017 at 6:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You have no cats. Problem solved.
  6. Oct 24, 2017 at 6:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I just noticed that you are using a Haltech Elite 2500.
    If you have your engine idling smoothly at 14.7, then is this when the exhaust smells bad, or during cold start?
  7. Oct 24, 2017 at 7:46 PM
    inwood customs
    Dave
    Wanted to say just that.... but fangered i was missing something as it seemed too easy.
    Drive thru and long waits with long tubes almost makes me cry if theres no wind
  8. Oct 24, 2017 at 7:55 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Don't idle in tunnels. :puke:
    ChadsPride and inwood customs like this.
  9. Oct 24, 2017 at 7:58 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine smells too. No cats. It’s a good smell, IMHO. :D
  10. Oct 24, 2017 at 7:59 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It's the smell of American Feeedom and Horsepowa!
  11. Oct 24, 2017 at 9:40 PM
    Hans512
    Hans512 [OP] Member
    Hans
    Tacoma 2015 1GR-FE
    Both of the times, but i can say the smell is a little higher during cold start.
    So the smell is the carbon monoxide?
    Regards
  12. Oct 24, 2017 at 10:24 PM
    Pigpen
    Dan
    Northwest Montana
    Carbon monoxide is odorless. You're smelling the unburned fuel the the cats would normally combust. I'm no expert in these matters, but it seems to me that you can expect unburned fuel when you remove the cats.
    Jester243 and ChadsPride like this.
  13. Oct 24, 2017 at 10:32 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    CO has no smell.
  14. Oct 24, 2017 at 11:04 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    As the others said, you are smelling unburned fuel that would be burned off by the cats in an OE system. Yes, stronger smell when cold is going to be normal. I get the same thing with my long tube headers. Slight smell on a nice warm day, burn your eyes on a cold one.
  15. Oct 25, 2017 at 5:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you actually have a Haltech Elite running your engine? I am quite curious of this. Did you tune it, or have a shop tune it?
    inwood customs likes this.
  16. Oct 25, 2017 at 10:14 AM
    Hans512
    Hans512 [OP] Member
    Hans
    Tacoma 2015 1GR-FE
    Yes its a Elite 2500, shop tuned, as said, idles good, the throttle response is also good as well as the power.
    Have haltechs in other cars using the same type of fuel and with no problems.
    Tried also leaning the afrs to 15.3 smell was slightly worse.
    Maybe injectors flow hitting the walls and fuel entering the combustion chamber in drops instead of atomized?
    Hans
  17. Oct 25, 2017 at 10:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Cold starts should be worse, as the mixture might be more rich. What is your base fuel pressure set to?
    It is normal to have that fuel in the exhaust smell, with no cats, so not a big deal to worry about.
  18. Oct 25, 2017 at 10:58 AM
    Hans512
    Hans512 [OP] Member
    Hans
    Tacoma 2015 1GR-FE
    Fuel is set to 45 psi, ill search for high flow cats or is there anything else i can do to lower the smell?
    Hans
  19. Oct 25, 2017 at 11:33 AM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Drive faster.
    In all seriousness- I had gone catless on my '04 STi, and my gf's '16 BMW 435i. The smell you just get used to, and it really is only noticeable when not moving. The power gains we got from deleting the cats and tuning far outweighed the smell.
    Torspd likes this.
  20. Oct 25, 2017 at 11:59 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    When I went with LT headers with the factory y-pipe, there was some additional exhaust fumes that I could smell when just idling. It was livable in my opinion. When I took it another step further and upgraded to a URD off-road y-pipe, the exhaust fumes was ridiculous. At stop lights, other cars would roll up their windows. I ran the setup like for for about 2-3wks before I decided to add a single Magnaflow hi-flow cat on the y-pipe. This helped eliminate 95% of the exhaust odor.
    LT headers with the o/r y-pipe provide a great power gain. Adding a cat took a little HP off the table, but it's worth it to not have to deal with the exhaust fumes.
    Torspd and Pigpen like this.
