Exhaust System replacement tips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hetkind, Nov 6, 2019.
  1. Nov 8, 2019 at 2:35 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Keep in mind the 4.0 is a 60° V. The exhaust pulses are closer together than in a 90° V. That makes getting a throaty sound difficult.
    It's not hard to make it louder. But a quality sound is a challenge. I had the TRD for about 6 months. I grew weary of all the drone, especially on the highway. Sold here on TW for $200. Best decision I've made for my rig.
    But at the end of the day it's a subjective thing, I suppose
    TheDevilYouLove likes this.
  2. Nov 9, 2019 at 5:31 AM
    hetkind
    hetkind [OP] Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I have solved my exhaust system issue. It was a clogged muffler after 120k miles, not unexpected. My local muffler shop, a Meinike that lost it's franchise and went independent, had a new, factory, takeoff system, from someone who wanted dual exhaust installed. They charged me $50 for the muffler/tailpipe, and $75 for the install, with new clamps and rubbers. I dropped off the truck, wife and I went for lunch in her car, and it was ready when we returned. I could not be happier. In another 120k miles, I will probably need another muffler! I gave the mechanic a $20 cash tip since I know my job barely covers his overhead.
    tacofish and TheDevilYouLove like this.
  3. Nov 9, 2019 at 2:44 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
  4. Nov 10, 2019 at 1:52 PM
    TacoTuesday1
    SD CA
    Aren't resonators designed to eliminate drone?
    What if you would have installed a resonator? I believe there is a particular brand and model number mentioned as being popular on the forum; I forget which one.
    That would be cool; if an exhaust can offer added sound when gassing it to know what the engine is doing not just by cluster, but also by ear; while still not droning at a constant (highway?) RPM.
    I've heard of this on other cars the closer people get to straight pipes; hopefully resonator(s) have fixed it for them.
    There is aftermarket exhaust like Armytrix (for Audi) that probably have a remote control to operate certain valves to change loudness, but they're thousands of dollars.
    Some cars nowadays stock (or even in the past) I think come with a similar thing, but it's probably controlled by engaging Sport Mode to change the exhaust, or does it on it's own automatically via vacuum. Higher engine RPM operates a valve through a vacuum line.
    I know the Tacoma exhaust does not have that level of "sophistication" but it's also that same basic ruggedness that makes Tacoma parts seem to last longer, be tougher, and easier to work on. So I'm not saying it's a bad thing.
