Exhaust system?
Discussion in 'Performance and Tuning' started by cyarbroughjr, Apr 24, 2007.
  1. Apr 24, 2007 at 6:14 PM
    cyarbroughjr
    cyarbroughjr [OP] New Member
    Does amyone know of a good exhaust system that will make the v-6 sound more throaty
  2. Apr 24, 2007 at 9:15 PM
    pinkslip
    pinkslip Member
    There are a bunch out there; Borla, Flowmaster, TRD, etc. Search around. I don't know of any "bad" brands. I personally am leaning towards the Borla, but the TRD is covered under warranty.
  3. Apr 27, 2007 at 9:55 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i've got the Magnaflow one that i got off of ebay from a guy and i love the sound of it. i can actually hear my truck now...
  4. Apr 27, 2007 at 10:37 AM
    sandie
    sandie Well-Known Member
    long beach, ca
    06 x-runner baby!
    jhodge...mind if i ask how much you nabbed that up for? liking the sound of that one too (based on their website)
  5. Apr 27, 2007 at 12:27 PM
    The_Hodge
    SC
  6. Apr 27, 2007 at 12:31 PM
    midV6size
    midV6size Active Member
    Ditto on the Magnaflow.
    Check here for prices on a Cat Back system, also mention that your a member of a truck forum, they'll nock off another 10%.
    http://www.hottexhaust.com/Index2.htm
  7. Apr 27, 2007 at 12:41 PM
    The_Hodge
    SC
    i paid 160 for it on ebay....i think the retail is 450 or so...keep checking on there for a deal if you can snag one
  8. Apr 28, 2007 at 10:25 AM
    Hoofhearted
    Hoofhearted C5 Meter Minder
    2017 TRD SPORT ACB 4V6
    I have TRD on mine, and I really like the tone. Add TRD cai and use 93 Octane, and you will notice a performance difference!
  9. Apr 29, 2007 at 3:29 PM
    Splangy
    Splangy Active Member
    Does your Tacoma engine have such a high compression ratio that 93 octane gas would actually help performance?
  10. Apr 30, 2007 at 7:04 AM
    Hoofhearted
    The V6 has 10:1. The manual states that "premium" fuel will provide the best
    performance. That along with the TRD exhaust and CAI really improved the performance of mine!
  11. Apr 30, 2007 at 7:35 AM
    Panama Red
    Panama Red Well-Known Member
    Hoofhearted:
    My '07 V6 owners manual does not say anything about using 93 octane, only regular gas. What year is your Taco ???
  12. Apr 30, 2007 at 9:18 AM
    TRDeity
    TRDeity Well-Known Member
    ATX
    2017 TRDpro
    The manual does state that 91 was used for all tests.
  13. Apr 30, 2007 at 10:46 AM
    Hoofhearted
    Mine is an `05.
    Cut and pasted from page 382 in my manual:
    Fuel type:
    2TR- FE engine—
    Unleaded gasoline, Octane Rating 87
    (Research Octane Number 91) or
    higher
    1GR- FE engine—
    (Research Octane Number91) or higher.
    For improved vehicle performance,
    the use of premium unleaded gasoline
    with an Octane Rating of 91 (Research
    Octane Number 96) or higher is recommended.
    Hoof?
  14. Apr 30, 2007 at 10:48 AM
    Panama Red
    On page 276 of the 2007 Owners Manual, it says "Select Octane Rating of 87 or higher. Use of unleaded gasoline with an Octane Rating lower than 87 may result in engine knocking. Persistant knocking can lead to engine damage."
    Just make sure you know the difference between Octane Rating and "Research Octane Number". Octane Rating of 87 = Research Octane Number 91.
    Sounds like they revised the Owners Manual since 2005.
  15. Apr 30, 2007 at 12:34 PM
    Panama Red
    This may explain the ongoing debate as to which Octane Rating to use:
    1GR-FE 4.0L V6 from a 2007 Toyota Tacoma. The 1GR-FE is the 4.0L version. Bore is 94 mm and stroke is 95 mm. Output is 236 hp (183 kW) at 5200 rpm with 266 lb-ft (382 Nm) of torque at 4000 rpm on 87 octane, and 239 hp at 5200 rpm with 278 lb-ft at 3700 rpm on 91 octane. This engine features Toyota's single VVT-i, variable valve timing, system and a compression ratio of 10.0:1. Inside, the 1GR uses a taper-squish combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are such 2 passages for each bank for a total of 4. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
    Some applications:
    2003 Toyota 4Runner
    2003 Toyota Land Cruiser (Europe)
    2005 Toyota Tacoma
    2005 Toyota Tundra
    2005 Toyota Fortuner (Middle East)
    2007 Toyota FJ Cruiser
    2007 Toyota Tacoma
  16. Apr 30, 2007 at 12:40 PM
    The_Hodge
    SC
    well i guess i learned something today. i didnt think that from 87-91 octane would boost 12lb of torque...not shabby...but i'm not paying it at these prices...lol
  17. May 4, 2007 at 5:45 AM
    The_Hodge
    SC
  18. Aug 11, 2007 at 12:15 PM
    ghostsix
    ghostsix Well-Known Member
    A WI farm, Sonora, Sedona, Lake Havesue and Canyon
    Impluse Red 2006 Toyota Tacoma TRD Off-road 4x4
    A Roo Bar comes to mind. I also protected the tail lamps. It is a farm and you back over stuff; Willows mostly. All of the factory options are on it. The dealership owner bought it for himself.He put a topper on it and pricey tyres. The Power Wagon does the heavy lifting.
    No that is what my 2006 Operators Manual says.
    I have not seen a differance between 87 and 91 or 93.
    No ethanol.
    This taco is never going to see 5200 RPM.
    So, over 87 is just a waste of resources.
  19. Aug 11, 2007 at 4:09 PM
    JPENI$
    JPENI$ Member
    i got mine for $150.... 40 series...including labor and exhaust tip
  20. Aug 11, 2007 at 6:48 PM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    I had a Magnaflow. Thought it was too loud. Sold it. Put back on my original cat-back. Discovered it was now too quiet. So I went and bought another MagnaFlow cat-back. Now it sounds good... or it did... or it does again.
