Exhaust system???
Discussion in 'Performance and Tuning' started by rubberduckytaco, Feb 10, 2013.
  1. Feb 10, 2013 at 5:39 PM
    rubberduckytaco
    rubberduckytaco [OP] Well-Known Member
    nicholas
    sumter sc
    09 prerunner dc sb
    running boards, backup camera, yellow fogs, camo interior
    What's the best system / combo to get? I'm looking for headers and full exhaust w dual exit
  2. Feb 10, 2013 at 9:37 PM
    chris66
    chris66 ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
    dust
    CO
    2004 Prerunner
    bfg at ko2, method double standard
    i am unsure about 2nd gens but in a thread i think a mod said 2.5 inch piping is the biggest you should go and short tube headers for 1st gens and long tube for 2nd gen. and the mod who posted about the pipe diameter also said "backpressure" doesn't affect performance, scavenging does ? but again with the headers i am not sure if you can run cats with them.
    my goal for exhaust in the future on my 3.4 v6 1st gen is short tube headers, front cat, 2.5 inch piping, and magnaflow 14 inch exhaust or at 2525 and a rear o2 sensor to replace the rear cat
    but do you have to worry about smog? if not i'd just get headers, and from the header back whatever piping and maybe a resonator and whatever muffler you want
  3. Feb 10, 2013 at 10:53 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Urdusa.com
    Gadgets got a few systems and headers
    I think 3" is overkill unless ur boosted.......gadget (urd) can help u there too
  4. Feb 11, 2013 at 2:53 AM
    rubberduckytaco
    nicholas
    sumter sc
    09 prerunner dc sb
    Flow master has a duel exit as well but the mbrp is cheaper
  5. Feb 11, 2013 at 2:57 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Doug Thorley long tube headers and the cat-back exhaust system of your choosing. There are a lot of exhaust manufacturers for our trucks I would recommend going to the exhaust sound clip thread and listening to different systems to see what you want.
  6. Feb 11, 2013 at 12:40 PM
    rubberduckytaco
    nicholas
    sumter sc
    09 prerunner dc sb
    Yeah I've done that I actually like the mbrp ALOT
  7. Feb 11, 2013 at 3:22 PM
    just2wd
    just2wd Well-Known Member
    Dan
    California
    07 PreRunner TRD Off Road
    my flowmaster 50 series is a dual, i'm not happy. it rubs up agaisnt the leafs...
  8. Feb 11, 2013 at 6:18 PM
    rubberduckytaco
    nicholas
    sumter sc
    09 prerunner dc sb
    Oh haha ok got it
  9. Feb 14, 2013 at 10:00 AM
    fireball946
    fireball946 Well-Known Member
    Patrick
    Conway, SC
    15' TRD sport
    3" Bilstein front coilovers, Light racing UCA's, 1/5" AAL, URD cat back exhaust, URD TCAI + maf cal, Pioneer double din, Kicker L7 solaberic, yellow fogs like a boss
    I've got the URD cat-back, 3" might seem like a bit of an overkill, its perfect if your truck is boosted, but its worked out great for a N/A truck like mine, plus it was easy to install, un-bolt the old and bolt in the new
  10. Feb 18, 2013 at 3:05 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Can not verify if true or not true, a reply on XRU, stated the URD will make less power than stock on a NA truck. I would recommend more research before spending money, unless sound is the only criteria.
    PK
