Exhaust tape/putty
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cb2589, Nov 6, 2010.
  1. Nov 6, 2010 at 6:50 PM
    Cb2589
    Cb2589 [OP] Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    Well I just put a Dynomax Super Turbo on my truck today. For the most part I'm impressed with it. Although when I let off the gas you can hear it going put-put-put-put from underneath. I used clamps on the inlet and outlet side. I was going to weld the outlet side because the pipe goes in the muffler (instead of the muffler outlet overtop of the exhaust pipe) but instead went with a clamp, so now it's kinda leaking out in that spot. My question is should I weld it? Or can I use the tape/putty the Advance store sells? I bought some and it says it's resistant up to 2000 degrees. Any input would be great!
  2. Nov 6, 2010 at 6:54 PM
    austinstaco
    austinstaco Well-Known Member
    Austin
    Dallas TX
    06 PreRunner
    to many
    Weld it
  3. Nov 6, 2010 at 7:00 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    x2
  4. Nov 6, 2010 at 7:27 PM
    austinstaco
    Austin
    Dallas TX
    06 PreRunner
    to many
    my flowmaster is all welded and it has a put put put when i let off the gas it is the intake vacuum creating a drag effect when the throttle closed
  5. Nov 6, 2010 at 7:29 PM
    Cb2589
    Corey
    VA
    it isn't the same, it wasn't there before and it's very noticeable around that spot.
  6. Nov 6, 2010 at 8:07 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Weld it and be done with it. Hell any muffler shop can do it for $10 bucks so unless your a cheapskate and like to do things half ass then yeah go ahead and put some putty on it.
  7. Nov 7, 2010 at 7:48 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Sounds to me its the wrong muffler if you have to half ass the install.
  8. Nov 7, 2010 at 9:25 AM
    Cb2589
    Corey
    VA
    It's not that it was a half ass install. If it was my choice I would've welded the whole thing, but I don't have keys to the shop at work, and the guy who helped me was on a time crunch to leave at close. So I got done what I could with the time I was given. Saturdays are the only days I get some free time at work. The only reason I got the putty/tape was because I can't stand to hear the sound and wanted it fixed asap.
  9. Nov 7, 2010 at 1:17 PM
    Yamaha Dave
    ^So you half assed it then...
  10. Nov 7, 2010 at 1:32 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    I guess what I was getting at was that the inlet/outlet size should of fit tight and not leaked with new clamps, that has to be a loose fit if putty is needed.
  11. Nov 7, 2010 at 3:48 PM
    Cb2589
    Corey
    VA
    I guess if you want to call it half ass then yeah it was half ass done. But i've never used clamps before so I wasn't sure how tight they should be, they already made a big print on the muffler and I didn't want to screw anything up. It doesn't really matter though I welded it today at a buddies house....and it doesn't sound like crap :D
  12. Nov 8, 2010 at 1:08 PM
    Yamaha Dave
    Well then you did right so that's what matters, personally what I was getting at was that it should of been done that way in the first place. It's all good though.
