Exhaust tip removal...help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pbird74, Jul 20, 2017.
  1. Jul 20, 2017 at 4:26 AM
    Pbird74
    Pbird74 [OP] Well-Known Member
    17MGMDCSR54x4
    Off Road Bilsteins, Pro grille
    So what seems like an easy uncomplicated endeavor has proven to be anything but. I loosened the clamp, pulled, twisted, sprayed WD-40, and still cannot get it off. Is there a trick to getting this thing off? Any advice is greatly appreciated.
    stun gun likes this.
  2. Jul 20, 2017 at 4:30 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Thors Hammer
    markelhof and Taco Larry like this.
  3. Jul 20, 2017 at 4:33 AM
    Pbird74
    17MGMDCSR54x4
    Hahaha...can I get one at NAPA?
    stun gun and markelhof like this.
  4. Jul 20, 2017 at 4:40 AM
    TacoRD16
    Houston, TX
    Only if you are worthy to carry the hammer.
    Baerskin, stun gun and markelhof like this.
  5. Jul 20, 2017 at 4:42 AM
    TacoRD16
    Houston, TX
    But for realzz just take a hammer and slowly tap each side back and worth. Also bend the tabs outwards after you pull the ring off.
  6. Jul 20, 2017 at 4:42 AM
    Pbird74
    17MGMDCSR54x4
    Alas, I am much too weak. The wrench was almost too much for me.
    mateo_roberto likes this.
  7. Jul 20, 2017 at 4:43 AM
    Pbird74
    17MGMDCSR54x4
    Hmmmm...will try that. Maybe my four year old daughter can get it.
    markelhof, tcjacado and Lawfarin like this.
  8. Jul 20, 2017 at 5:14 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    A prybar or screw driver to help loosen the clap will work, that with the spray should slide it right off.
  9. Jul 20, 2017 at 5:25 AM
    Pbird74
    17MGMDCSR54x4
    Thanks! I'll report back later if my fingers aren't too tired to text.
    DA3, markelhof and Lawfarin[QUOTED] like this.
  10. Jul 20, 2017 at 6:08 AM
    Pbird74
    17MGMDCSR54x4
    Got it! Dead blow hammer and encouragement from my daughter made all the difference. Thanks to you guys!
  11. Jul 20, 2017 at 12:11 PM
    Pbird74
    17MGMDCSR54x4
    Blacked out exhaust tip and pipe. Will post pics soon if anyone is interested.
  12. Jul 20, 2017 at 12:12 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    You change the pipeing, or just high temp paint?
  13. Jul 20, 2017 at 1:05 PM
    Pbird74
    17MGMDCSR54x4
    High temp enamel. Duplicolor engine enamel, low gloss black.
    markelhof and James_Bond like this.
  14. Jul 20, 2017 at 1:06 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Did you really have to take it off to do that? Just curious.
  15. Jul 20, 2017 at 1:07 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    How far up did you paint on the actual pipe? or did you just do the tip
  16. Jul 20, 2017 at 1:08 PM
    Pbird74
    17MGMDCSR54x4
    No, but I wanted it to look decent, and I thought removing it would help.
  17. Jul 20, 2017 at 1:08 PM
    Pbird74
    17MGMDCSR54x4
    Just to the rubber hanger.
  18. Jul 20, 2017 at 1:10 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    ok cool.
    My truck didn't come with one and I was thinking of painting it before it starts to rust.
    how did you cover the rest of the truck if you painted all the way to the hook?
  19. Jul 20, 2017 at 1:33 PM
    Pbird74
    17MGMDCSR54x4
    Just with painters tape and newspaper.
    James_Bond[QUOTED] likes this.
  20. Jul 20, 2017 at 2:24 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
